Reset PAGE NUMBER [message #262906] |
Fri, 07 December 2007 09:56  |
Originally posted by: sergiogomes.uxs.pt
Hi!
I have a table to iterate a Dataset (collection), in this table i have
groups!
My Report generates a PDF with 8 pages, each 2 pages corresponding a
group, i have Page Number in footer of report.
My problem is: the numeration of PDF file is 1,2,3,4,...8! but i want a
reset in page number for each group like this:
Group1 - Page 1,2 - Original
Group2 - Page 1,2 - Duplicate
Is there a way to do this???
Thanks 4 your help.
Re: Reset PAGE NUMBER [message #262934 is a reply to message #262906] |
Fri, 07 December 2007 16:42  |
The attached example will work if you are using the frameset mapping in
the viewer. It will not work if you are using run mapping.
It will work with the api as long as you do not do a runandrender task.
Jason
<report xmlns="http://www.eclipse.org/birt/2005/design" version="3.2.15"
id="1">
<property name="createdBy">Eclipse BIRT Designer Version
2.2.1.r221_v20070924 Build <2.2.0.v20070924-1550></property>
<property name="units">in</property>
<property name="comments">Copyright (c) 2007 <<Your Company
Name here>></property>
<html-property name="description">Creates a blank report with no
predefined content.</html-property>
<method
name="beforeFactory"><![CDATA[importPackage(Packages.java.lang);
reportContext.setPersistentGlobalVariable("pgcnt", new Integer(0));
orderlast="none";
ordercurrent="none";]]></method>
<text-property name="displayName">Blank Report</text-property>
<property name="iconFile">/templates/blank_report.gif</property>
<data-sources>
<oda-data-source
extensionID="org.eclipse.birt.report.data.oda.jdbc" name="Data Source"
id="6">
<property
name="odaDriverClass">org.eclipse.birt.report.data.oda.sampledb.Driver </property>
<property name="odaURL">jdbc:classicmodels:sampledb</property>
<property name="odaUser">ClassicModels</property>
</oda-data-source>
</data-sources>
<data-sets>
<oda-data-set
extensionID="org.eclipse.birt.report.data.oda.jdbc.JdbcSelectDataSet "
name="Data Set" id="7">
<list-property name="columnHints">
<structure>
<property name="columnName">ORDERNUMBER</property>
<property name="displayName">ORDERNUMBER</property>
</structure>
<structure>
<property name="columnName">PRODUCTCODE</property>
<property name="displayName">PRODUCTCODE</property>
</structure>
<structure>
<property name="columnName">QUANTITYORDERED</property>
<property name="displayName">QUANTITYORDERED</property>
</structure>
<structure>
<property name="columnName">PRICEEACH</property>
<property name="displayName">PRICEEACH</property>
</structure>
<structure>
<property name="columnName">ORDERLINENUMBER</property>
<property name="displayName">ORDERLINENUMBER</property>
</structure>
</list-property>
<structure name="cachedMetaData">
<list-property name="resultSet">
<structure>
<property name="position">1</property>
<property name="name">ORDERNUMBER</property>
<property name="dataType">integer</property>
</structure>
<structure>
<property name="position">2</property>
<property name="name">PRODUCTCODE</property>
<property name="dataType">string</property>
</structure>
<structure>
<property name="position">3</property>
<property name="name">QUANTITYORDERED</property>
</structure>
<structure>
<property name="position">4</property>
<property name="name">PRICEEACH</property>
<property name="dataType">float</property>
</structure>
<structure>
<property name="position">5</property>
<property name="name">ORDERLINENUMBER</property>
</structure>
</list-property>
</structure>
<property name="dataSource">Data Source</property>
<structure>
<property name="nativeName">ORDERNUMBER</property>
<property name="nativeDataType">4</property>
</structure>
<structure>
<property name="nativeName">PRODUCTCODE</property>
<property name="nativeDataType">12</property>
</structure>
<structure>
<property name="nativeName">QUANTITYORDERED</property>
</structure>
<structure>
<property name="nativeName">PRICEEACH</property>
<property name="nativeDataType">8</property>
</structure>
<structure>
<property name="nativeName">ORDERLINENUMBER</property>
<property name="nativeDataType">5</property>
</structure>
</list-property>
<property name="queryText">select *
from orderdetails</property>
<xml-property name="designerValues"><![CDATA[<?xml
version="1.0" encoding="UTF-8"?>
<model:DesignValues
xmlns:design="http://www.eclipse.org/datatools/connectivity/oda/design"
xmlns:model="http://www.eclipse.org/birt/report/model/adapter/odaModel">
<Version>1.0</Version>
<design:ResultSets derivedMetaData="true">
<design:resultSetDefinitions>
<design:resultSetColumns>
<design:resultColumnDefinitions>
<design:attributes>
<design:name>ORDERNUMBER</design:name>
<design:position>1</design:position>
<design:nativeDataTypeCode>4</design:nativeDataTypeCode>
<design:precision>10</design:precision>
<design:scale>0</design:scale>
<design:nullability>Nullable</design:nullability>
<design:uiHints>
<design:displayName>ORDERNUMBER</design:displayName>
</design:uiHints>
</design:attributes>
<design:usageHints>
<design:label>ORDERNUMBER</design:label>
<design:formattingHints>
<design:displaySize>11</design:displaySize>
</design:formattingHints>
</design:usageHints>
</design:resultColumnDefinitions>
<design:attributes>
<design:name>PRODUCTCODE</design:name>
<design:position>2</design:position>
<design:nativeDataTypeCode>12</design:nativeDataTypeCode>
<design:precision>15</design:precision>
<design:uiHints>
<design:displayName>PRODUCTCODE</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>PRODUCTCODE</design:label>
<design:displaySize>15</design:displaySize>
<design:attributes>
<design:name>QUANTITYORDERED</design:name>
<design:position>3</design:position>
<design:uiHints>
<design:displayName>QUANTITYORDERED</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>QUANTITYORDERED</design:label>
<design:attributes>
<design:name>PRICEEACH</design:name>
<design:position>4</design:position>
<design:nativeDataTypeCode>8</design:nativeDataTypeCode>
<design:uiHints>
<design:displayName>PRICEEACH</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>PRICEEACH</design:label>
<design:displaySize>22</design:displaySize>
<design:attributes>
<design:name>ORDERLINENUMBER</design:name>
<design:position>5</design:position>
<design:nativeDataTypeCode>5</design:nativeDataTypeCode>
<design:precision>5</design:precision>
<design:uiHints>
<design:displayName>ORDERLINENUMBER</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>ORDERLINENUMBER</design:label>
<design:displaySize>6</design:displaySize>
</design:resultSetColumns>
</design:resultSetDefinitions>
</design:ResultSets>
</model:DesignValues>]]></xml-property>
</oda-data-set>
</data-sets>
<styles>
<style name="crosstab-cell" id="4">
<property name="borderBottomColor">#CCCCCC</property>
<property name="borderBottomStyle">solid</property>
<property name="borderBottomWidth">1pt</property>
<property name="borderLeftColor">#CCCCCC</property>
<property name="borderLeftStyle">solid</property>
<property name="borderLeftWidth">1pt</property>
<property name="borderRightColor">#CCCCCC</property>
<property name="borderRightStyle">solid</property>
<property name="borderRightWidth">1pt</property>
<property name="borderTopColor">#CCCCCC</property>
<property name="borderTopStyle">solid</property>
<property name="borderTopWidth">1pt</property>
</style>
<style name="crosstab" id="5">
</style>
</styles>
<page-setup>
<simple-master-page name="Simple MasterPage" id="2">
<page-footer>
<text id="3">
<method name="onRender"><![CDATA[newpagestr =
reportContext.getPersistentGlobalVariable("pgstr"+pageNumber);
this.text = " Page Number: " + newpagestr;]]></method>
<property name="contentType">html</property>
</text>
</page-footer>
</simple-master-page>
</page-setup>
<body>
<table id="8">
<property name="width">100%</property>
<property name="dataSet">Data Set</property>
<list-property name="boundDataColumns">
<structure>
<expression
name="expression">dataSetRow["ORDERNUMBER"]</expression >
</structure>
<structure>
<expression
name="expression">dataSetRow["PRODUCTCODE"]</expression >
</structure>
<structure>
<expression
name="expression">dataSetRow["QUANTITYORDERED"]</expression >
</structure>
<structure>
<expression
name="expression">dataSetRow["PRICEEACH"]</expression>
</structure>
<structure>
<expression
name="expression">dataSetRow["ORDERLINENUMBER"]</expression >
</structure>
</list-property>
<method name="onPageBreak"><![CDATA[importPackage(
Packages.java.io );
importPackage( Packages.java.lang );
pgcnt = reportContext.getPersistentGlobalVariable("pgcnt");
if( orderlast.equals("none") || orderlast.equals(ordercurrent) ){
pg = parseInt(pgcnt) + parseInt(1);
}else{
pg= parseInt(1);
orderlast = ordercurrent;
reportContext.setPersistentGlobalVariable("pgcnt", new Integer(pg));
reportContext.setPersistentGlobalVariable("pgstr"+pageNumber, new
Integer(parseInt(pg)));]]></method>
<property name="pageBreakInterval">3</property>
<column id="37"/>
<column id="38"/>
<column id="39"/>
<column id="40"/>
<column id="41"/>
<header>
<row id="9">
<cell id="10">
<label id="11">
<text-property
name="text">ORDERNUMBER</text-property>
</label>
</cell>
<cell id="12">
<label id="13">
<text-property
name="text">PRODUCTCODE</text-property>
</label>
</cell>
<cell id="14">
<label id="15">
<text-property
name="text">QUANTITYORDERED</text-property>
</label>
</cell>
<cell id="16">
<label id="17">
<text-property
name="text">PRICEEACH</text-property>
</label>
</cell>
<cell id="18">
<label id="19">
<text-property
name="text">ORDERLINENUMBER</text-property>
</label>
</cell>
</row>
</header>
<group id="42">
<property name="groupName">NewTableGroup1</property>
<property name="interval">none</property>
<property name="sortDirection">asc</property>
<expression name="keyExpr">row["ORDERNUMBER"]</expression>
<structure name="toc">
<expression
name="expressionValue">row["ORDERNUMBER"]</expression>
</structure>
<property name="repeatHeader">true</property>
<property name="hideDetail">false</property>
<property name="pageBreakAfter">always</property>
<property name="pageBreakBefore">auto</property>
<property name="pageBreakInside">auto</property>
<header>
<row id="43">
<cell id="44">
<data id="55">
<property
name="resultSetColumn">ORDERNUMBER</property>
</data>
</cell>
<cell id="45"/>
<cell id="46"/>
<cell id="47"/>
<cell id="48"/>
</row>
</header>
<footer>
<row id="49">
<cell id="50"/>
<cell id="51"/>
<cell id="52"/>
<cell id="53"/>
<cell id="54"/>
</row>
</footer>
</group>
<detail>
<row id="20">
<method name="onCreate"><![CDATA[ordercurrent =
this.getRowData().getColumnValue("ORDERNUMBER").toString();]] ></method>
<cell id="21">
<data id="22">
<property
</data>
</cell>
<cell id="23">
<data id="24">
<property
name="resultSetColumn">PRODUCTCODE</property>
</data>
</cell>
<cell id="25">
<data id="26">
<property
name="resultSetColumn">QUANTITYORDERED</property>
</data>
</cell>
<cell id="27">
<data id="28">
<property
name="resultSetColumn">PRICEEACH</property>
</data>
</cell>
<cell id="29">
<data id="30">
<property
name="resultSetColumn">ORDERLINENUMBER</property>
</data>
</cell>
</row>
</detail>
<footer>
<row id="31">
<cell id="32"/>
<cell id="33"/>
<cell id="34"/>
<cell id="35"/>
<cell id="36"/>
</row>
</footer>
</table>
</body>
</report>
sergiogomes wrote:
> Hi!
> groups!
> Thanks 4 your help.
FUDForum. Page generated in 0.03846 seconds
