Home » Archived » XML Schema Definition (XSD) » Schema Validator
Schema Validator [message #26023] Mon, 04 August 2003 14:50 Go to next message
Originally posted by: cipher8000.yahoo.com
Hi Ed,
Is there any sample for using external Schema Validator with XSDSchema
object? I am thinking of using Xerces or Sun's MSV Validator.
i guess, i can get the real Element from XSDSchema and use that Element with
these validator? but is there any better way of doing this.
-muruga
Re: Schema Validator [message #26063 is a reply to message #26023] Mon, 04 August 2003 15:04 Go to previous messageGo to next message
Muruga,
XSD supports validation directly:
http://dev.eclipse.org/viewcvs/indextech.cgi/~checkout~/xsd- home/docs/javadoc/org/eclipse/xsd/util/XSDPrototypicalSchema .html#printSchema(java.lang.String)
Validation involves loading many schema documents, and I don't think there is an
easy way to feed all the already loaded documents of the XSD model into some
other validator. You'd have to look to those other tools for ways to drive
schema documents into them...
Muruga wrote:
> Hi Ed,
> -muruga
Re: Schema Validator [message #26104 is a reply to message #26063] Mon, 04 August 2003 15:30 Go to previous messageGo to next message
Hi Ed,
Thanks for the link..It was my mistake, i didn't explain it correctly.
I wanted to validate an XML document (instance) against a XSDSchema. I have
XSDSchema objects constructed and i received an XML document. Now i want to
pass these XSDSchema & XML document to an Validator which can validate
Looked at Xerces Schema Validator..which takes String version of XSD and
String version of XML document for validation.
-muruga
"Ed Merks" <merks@ca.ibm.com> wrote in message
news:3F2EAE44.E13ED457@ca.ibm.com...
Muruga,
c/org/eclipse/xsd/util/XSDPrototypicalSchema.html#printSchem a(java.lang.Stri
ng)
is an
Muruga wrote:
> Hi Ed,
with
> -muruga
Re: Schema Validator [message #26144 is a reply to message #26104] Tue, 05 August 2003 08:02 Go to previous message
Muruga,
That makes more sense. ;-)
As far as Xerces goes, the only way I know of to drive validation is to provide
InputSources which will load everything that's needed from those.
I've been wanting to provide direct support for (incremental) instance
validation with the XSD model too, but I just haven't had time and probably
won't have time for a while at least. The model already supports direct
validation of simple types via XSDSimpleTypeDefinition.assess and
XSDEditor.GenericXMLResourceImpl.doLoad contains code that shows how complex
content can be validated, but more needs to be done to fully validate complex
content...
Muruga Chinnananchi wrote:
> Hi Ed,
> -muruga
> Muruga,
> ng)
> is an
> Muruga wrote:
> > Hi Ed,
> with
> > -muruga
Re: Schema Validator [message #575564 is a reply to message #26023] Mon, 04 August 2003 15:04 Go to previous message
Muruga,
Muruga wrote:
> Hi Ed,
> -muruga
Re: Schema Validator [message #575593 is a reply to message #26063] Mon, 04 August 2003 15:30 Go to previous message
Hi Ed,
-muruga
Muruga,
ng)
is an
Muruga wrote:
> Hi Ed,
with
> -muruga
Re: Schema Validator [message #575634 is a reply to message #26104] Tue, 05 August 2003 08:02 Go to previous message
Muruga,
content...
> Hi Ed,
> -muruga
> Muruga,
> ng)
> is an
> Muruga wrote:
> > Hi Ed,
> with
> > -muruga
Previous Topic:Schema Validator
Next Topic:How to traverse sequence / element within ComplexType
Current Time: Sun Jul 27 02:56:08 EDT 2025
Powered by FUDForum. Page generated in 0.03328 seconds
