Home » Eclipse Projects » Eclipse Platform » per-project compiler settings, shared via cvs
per-project compiler settings, shared via cvs [message #262696] Tue, 20 July 2004 13:34 Go to next message
Originally posted by: eclipse.afyfe.com
A co-worker set up per-project compiler settings for a project. As a
result, the file .settings/org.eclipse.jdt.core.prefs was created in the
project directory, and this new directory and file were both checked into
cvs.
When I did an update, I got them. This did not enable "Use Project
Settings" for the compiler options, so I selected it myself via the
project properties.
However, eclipse did not use the settings in the .settings directory.
Instead it created for me a new file
metadata/.plugins/org.eclipse.core.resources/.projects/PROJ_ NAME/org.eclipse.jdt.core/.jprefs
and used it instead. This file, unlike the other, is not shared via CVS.
When does eclipse use one or the other? And can I request that it use one
over the other?
(We collectively use eclipse 3.0 on either osx and winxp.)
--Andy Fyfe
Re: per-project compiler settings, shared via cvs [message #262706 is a reply to message #262696] Tue, 20 July 2004 14:35 Go to previous messageGo to next message
Originally posted by: akiezun.cutthis.mit.this.edu.andthis
Andy,
this is not supported yet.
see https://bugs.eclipse.org/bugs/show_bug.cgi?id=59258
a.
> cvs.
> project properties.
> over the other?
> --Andy Fyfe
Re: per-project compiler settings, shared via cvs [message #262939 is a reply to message #262706] Wed, 21 July 2004 13:01 Go to previous message
The bug report and some comparison has solved the
mystery.
While I'm nominally using eclipse v 3.0.0, build
200400251208, some machines have version 3.0.0 of
the Java Development Tools Core while at least one
other has 3.0.0.cheetah06. And it sounds like the
cheetah version brings the newer behaviour.
--Andy
adam kiezun wrote:
> Andy,
> a.
Previous Topic:Eclipse & SSH support
Next Topic:3.0 new install - Java menu missing from Preferences
Current Time: Fri Jul 18 05:51:41 EDT 2025
Powered by FUDForum. Page generated in 0.38751 seconds
