Using IMP for LPG in non-IMP target [message #26007] |
Thu, 15 January 2009 15:34  |
Originally posted by: mike.aol.com
I need to use LPG for parsing data within my application, and I would
like to use the IMP tooling to help me build it. The application, in one
of its forms, is not even eclipse, so I have to embed the lpg runtime in
my application. It looks like IMP might be helpful for developing my
parser, but I'm not so sure. The default grammar created by the New LPG
Grammar (non-IMP) generates an example lexer.gi file that cannot resolve
its reference to LexerVeryBasicMapF.gi. It is defined in the
org.eclipse.imp.lpg.metatooling_0.1.79/templates directory which is the
value of the LPG include path, so why does it generate the "could not be
read" error? Even when I copy the .gi file into the same directory as
the generated FoobarLexer.gi, it doesn't get found. The LPG preferences
let me override the include path, but I really would like to use a
relative path to my workspace or project. That doesn't seem to work either.
I'm simultaneously trying to learn LPG, so I'm sure there is a simple
solution. I would expect the generated grammar to compile without change.
Mike Gering
Re: Using IMP for LPG in non-IMP target [message #26851 is a reply to message #26007] |
Tue, 24 February 2009 10:13  |
Hi Mike,
Sorry for the late response.
We've recently split the LPG feature in two to separate the runtime
componenents from the compile-time components. Also, we removed the
LPG templates from org.eclipse.imp.lpg.metatooling, since it turned
out that they didn't actually depend on IMP.
As for your troubles with the include path settings, can you post
more details as to where the templates files are located and what
include path you used? Naturally, this ought to work (and it does
for us).
-- Bob
Robert M. Fuhrer
Research Staff Member
Programming Technologies Dept.
IBM T.J. Watson Research Center
IDE Meta-tooling Platform Project Lead (http://www.eclipse.org/imp)
X10: Productive High-Performance Parallel Programming (http://x10.sf.net)
Re: Using IMP for LPG in non-IMP target [message #574658 is a reply to message #26007] |
Mon, 19 January 2009 08:20  |
I've learned a few things and have answered (most) of my questions. What
I've learned is that I can use the IMP grammar editor for a non-IMP
project is mostly ok. But I should use my own external tool launcher to
invoke the lpg generator. And I should avoid using templates that rely
on the IMP infrastructure.
Mike Gering
Re: Using IMP for LPG in non-IMP target [message #574682 is a reply to message #26050] |
Tue, 20 January 2009 03:42  |
Hi Mike
Your experiences sound very familiar. Unfortunately I've forgotten
the details of the stupid mistakes I made and how I solved them.
While your problems are fresh in your mind it might be helpful
to share them.
I suspect that there are at least a couple of examples or wizards
that should be adjusted to be more helpful.
Ed Willink
Re: Using IMP for LPG in non-IMP target [message #574706 is a reply to message #26050] |
Thu, 22 January 2009 22:15  |
Mike,
The dependence between the lpg for non-imp is minimal as my memory, only two
interfaces( IParser,ILexer). You can simply copy these files to your
standalone package. It is nearly clear.
The gramme dependence aslo can be extracted from some projects
(...metatooling.., sorry for forgetting^_^). But the runtime is not related
to this gramme files dependence, so you can ignore this problem.
Jin
"Mike Gering" <mike@aol.com>
> invoke the lpg generator. And I should avoid using templates that rely on
> Mike Gering
Re: Using IMP for LPG in non-IMP target [message #575049 is a reply to message #26007] |
Hi Mike,
for us).
-- Bob
Robert M. Fuhrer
FUDForum. Page generated in 0.05712 seconds
