Home » Language IDEs » AspectJ » AJDT Example: Autocompletion Doesn't Work
AJDT Example: Autocompletion Doesn't Work [message #26004] |
Wed, 17 September 2003 13:00  |
Originally posted by: eeide.cs.utah.edu
I was going through the online ``Getting Started with AJDT'' document (URL
below), and I came across a part of the example that doesn't work for me. I'd
like to determine if the example is out of date, or if I've installed AJDT
incorrectly.
First, my stats: Eclipse 2.1.1, AJDT 1.1.3, Sun JDK 1.4.2_01, Windows XP.
Going through the user guide, on the ``Adding a New Aspect to Your Project''
page:
< http://dev.eclipse.org/viewcvs/indextech.cgi/~checkout~/org. eclipse.ajdt/plugins/org.eclipse.ajdt/doc/AJDTug/ajdt-addasp ect.html>
It says:
Start typing inside the body of the aspect: "pointcut greeting() : exe"
and then hit "Ctrl+Space" (code completion). The editor will suggest
auto-completions for the execution pointcut: [...]
When I do this, I simply get a message in the Eclipse status bar:
``No completions available.''
I believe that I am using the proper editor and so on; AspectJ keywords are
highlighted in the editor, and I can compile and run AspectJ programs.
So, is the online example wrong, or have I missed some configuration bit?
Thanks ---
Eric.
Eric Eide <eeide@cs.utah.edu> . University of Utah School of Computing
http://www.cs.utah.edu/~eeide/ . +1 (801) 585-5512 voice, +1 (801) 581-5843 FAX
Re: AJDT Example: Autocompletion Doesn't Work [message #26126 is a reply to message #26004] |
Thu, 18 September 2003 09:28   |
On Wed, 17 Sep 2003 11:00:03 -0600 (MDT), Eric Eide <eeide@cs.utah.edu>
> (URL
> me. I'd
> AJDT
> incorrectly.
> Project''
> page:
> It says:
> are
> Thanks ---
> Eric.
Hi Eric,
You are doing everything right. What's wrong is that the "Getting Started
with AJDT" user guide is actually for AJDT 1.1.4 which has not been
released yet. Auto-completion is one of the new features in 1.1.4.
We are *very* close to releasing 1.1.4 but, because of one or two
unforeseen things that have fallen out of the QA phase on it and AspectJ
1.1.1 on which it depends, things have slipped a little. We will sort this
now.
George
Re: AJDT Example: Autocompletion Doesn't Work [message #26165 is a reply to message #26126] |
Thu, 18 September 2003 10:21  |
"George" == George Harley <gharley@uk.ibm.com> writes:
George> You are doing everything right. What's wrong is that the
George> "Getting Started with AJDT" user guide is actually for AJDT
George> 1.1.4 which has not been released yet. Auto-completion is one
George> of the new features in 1.1.4.
Ah, thanks! Now that I look, I see that 1.1.4 is specified several times in
the guide --- it's even in the in subtitle! Still, somehow I missed it.
I will also mention that in following the guide with 1.1.3, I couldn't seem to
make the Aspect Visualizer do anything for the (trivial) example program; the
visualizer window was always blank. When 1.1.4 is available, I'll try again,
and submit a more detailed report if necessary.
Thanks again ---
Eric.
Re: AJDT Example: Autocompletion Doesn't Work [message #571415 is a reply to message #26004] |
> (URL
> me. I'd
> AJDT
> incorrectly.
> Project''
> page:
> It says:
> are
> Thanks ---
> Eric.
Hi Eric,
now.
George
Re: AJDT Example: Autocompletion Doesn't Work [message #571448 is a reply to message #26126] |
Thanks again ---
Eric.
Current Time: Tue Jul 22 20:34:38 EDT 2025
Powered by FUDForum. Page generated in 0.07535 seconds
