Home » Modeling » GMF (Graphical Modeling Framework) » Can I change compartment positions
Can I change compartment positions [message #25997] |
Tue, 22 August 2006 11:32  |
I have 2 compartments in a figure, normally they should layout vertically,
now I wish to layout them horizontally.
Can I realize this through modeling or I have to modify codes directly?
ZhangHao
Re: Can I change compartment positions [message #26079 is a reply to message #25997] |
Tue, 22 August 2006 12:08   |
1. In the gmfgraph model define 3 rectangles Root, Comp1 and Comp2.
2. Layout Comp1 and Comp2 inside Root using gmf layouts (e.g, set
BorderLayout for root, BorderLayoutData(beginning, not vertical) for Comp1
and BorderLayoutData(end, not vertical) for Comp2). Feel free to insert any
auxiliary figures between Root and Comp's to adjust layout. Ensure that
Comp1 and Comp2 both are children (probably deep children) of Root.
3. Define Diagram Node to reference Root rectangle, and 2 Diagram
Compartments to reference Comp1 and Comp2.
Michael
"Hao Zhang" <bjzhanghao@21cn.com> wrote in message
news:ecf83a$nju$1@utils.eclipse.org...
> ZhangHao
Re: Can I change compartment positions [message #26668 is a reply to message #26079] |
Wed, 23 August 2006 05:17   |
Hi, thanks a lot that it works.
But it seems that when I add any layout(for example FlowLayout) to
comp1/comp2, I couldn't add any child into it in generated application. I
need comp1 and comp2 both use flowlayout other than list layout or
xylayout.
I use GMF1.0 release, does it matter?
Michael Golubev wrote:
> Michael
>> ZhangHao
Re: Can I change compartment positions [message #26997 is a reply to message #26668] |
Wed, 23 August 2006 08:07   |
This part of the implementation definitely needs some improvements. Please
submit bugzilla issue with a bit more details about the problem.
Nevertheless, it is not clear for me why you need to set inner layouts for
compartment figures.
Probably it make sense to remove any inner layouts from them and adjust
listLayout property in the gmfgen model for GenCompartments.
Michael
"zhanghao" <bjzhanghao@21cn.com> wrote in message
news:e5cdf6765c32f9e8cc8117e4c6cccaf0$1@www.eclipse.org...
> xylayout.
>> Comp1 and BorderLayoutData(end, not vertical) for Comp2). Feel free to
>> insert any auxiliary figures between Root and Comp's to adjust layout.
>> Ensure that Comp1 and Comp2 both are children (probably deep children) of
>> Root.
>> Regards,
>> Michael
>>> Hi,
>>> vertically, now I wish to layout them horizontally.
>>> ZhangHao
Current Time: Tue Jul 22 14:20:46 EDT 2025
Powered by FUDForum. Page generated in 0.04479 seconds
