Home » Archived » BIRT » Put properties file in Fragment Plugin
Put properties file in Fragment Plugin [message #262485] Fri, 30 November 2007 11:37
Originally posted by: jean-phlippe.vandara.laposte.net
I use some properties files to localize my report. All the files are in
the same directory and deployed in the same jar file. Everything works
fine.
I would like to know if there is a way to put the properties files in a
fragment plugin so that I can add new localisations without modifying my
initial plugin?
Jean-Philippe.
Previous Topic:Dataset using datasets and tables
Next Topic:birt 2.2 API
Current Time: Mon Jul 21 22:16:39 EDT 2025
Powered by FUDForum. Page generated in 0.04801 seconds
