Home » Eclipse Projects » Eclipse Platform » export/import run/debug configurations?
export/import run/debug configurations? [message #262092] Fri, 16 July 2004 13:34 Go to next message
Periodically I need to create a new devspace (i.e. the directory
pointed to by -data when running 'eclipse'). Once upon a time, the
most onerous part of this task was recreating one's preferences, but
then some kind soul(s) implemented Windows>Preferences>{Export,
Import}, which made that much easier. (It would be even easier if
they'd just put a mnemonic on the button :-)
Then, the most onerous part of this task was recreating one's
projects, but then some kind soul(s) implemented File>{Export,
Import}>Team Project Set, which made the task much easier. (It would
be even easier if they'd implement {Select All, Clear All} for the
viewer :-)
Now, the most onerous part of changing devspaces is recreating one's
{debug, run} configurations, i.e. the things you see in the dialog you
get when you Run>{Debug..., Run...}. Is there currently some way to
make them {export, import}able? If not I'll do an FR, but JIC ...
If possible please post to me as well as the newsgroup, and TIA.
(Also please lemme know if I'm asking the wrong group.)
Re: export/import run/debug configurations? [message #262115 is a reply to message #262092] Fri, 16 July 2004 14:24 Go to previous message
Originally posted by: richkulp.NO.SPAM.us.ibm.com
If you take the configurations and go to the Common tab page, you can
select "Shared." This allows you to put the configurations into a
project(s). Then the can be shared through the standard project share
conventions.
Thanks, Rich Kulp
Previous Topic:can't see 'visual class' option
Next Topic:How to write an Eclipse debugger
Current Time: Tue Jul 15 14:34:28 EDT 2025
Powered by FUDForum. Page generated in 0.06066 seconds
