XPath pattern error [message #25941] |
Sun, 03 August 2003 12:43  |
Originally posted by: guyos.attglobal.net
I applied a 'unique' constraint on an element an I get an pattern error
message (in the IDE) for the attribute 'xpath' of the 'selector' element
when the value is:
myNS:elem1 | myNS:elem2
When I use the same schema with all the feature of validation with the
xerces parser I don't get an error message and the parser does detect when
the constraint is broken.
The schema also passes validation with IBM's SQC
Re: XPath pattern error [message #25982 is a reply to message #25941] |
Sun, 03 August 2003 16:38  |
--------------58F52F675882AE5CE18516A1
Content-Type: text/plain; charset=us-ascii
Guy,
The XSD model is strictly following the pattern definition as it appears in
the normative XMLSchema.xsd:
<xs:element name="selector" id="selector">
<xs:annotation>
<xs:documentation
source="http://www.w3.org/TR/xmlschema-1/#element-selector"/>
</xs:annotation>
<xs:complexType>
<xs:complexContent>
<xs:extension base="xs:annotated">
<xs:attribute name="xpath" use="required">
<xs:simpleType>
<xs:annotation>
<xs:documentation>A subset of XPath expressions for use
in selectors</xs:documentation>
<xs:documentation>A utility type, not for public
use</xs:documentation>
</xs:annotation>
<xs:restriction base="xs:token">
<xs:annotation>
<xs:documentation>The following pattern is intended to
allow XPath
expressions per the following EBNF:
Selector ::= Path ( '|' Path )*
Path ::= ('.//')? Step ( '/' Step )*
Step ::= '.' | NameTest
NameTest ::= QName | '*' | NCName ':' '*'
child:: is also allowed
</xs:documentation>
</xs:annotation>
<xs:pattern
value=" (\.//)?(((child::)?((\i\c*:)?(\i\c*|\*)))|\.)(/(((child::)?( (\i\c*:)?(\i\c*|\*)))|\.))*(\|(\.//)?(((child::)?((\i\c*:)?( \i\c*|\*)))|\.)(/(((child::)?((\i\c*:)?(\i\c*|\*)))|\.))*)* ">
</xs:pattern>
</xs:restriction>
</xs:simpleType>
</xs:attribute>
</xs:extension>
</xs:complexContent>
</xs:complexType>
</xs:element>
I don't think this pattern allows a space character to appear within the
expression. Perhaps the other processors are more forgiving and simply ignore
spaces, but I think the XSD model's strictness is "more correct." Removing
the spaces from the expression does eliminate the error message. Okay?
> when the value is:
Content-Type: text/html; charset=us-ascii
<!doctype html public "-//w3c//dtd html 4.0 transitional//en">
<html>
Guy,
<p>The XSD model is strictly following the <font color="#3333FF">pattern
definition</font> as it appears in the normative XMLSchema.xsd:
<blockquote> <xs:element name="selector" id="selector">
<br> <xs:annotation>
<br> <xs:documentation source="<A HREF="http://www.w3.org/TR/xmlschema-1/#element-selector"/">http://www.w3.org/TR/xmlschema-1/#element-selector"/</A>>
<br> </xs:annotation>
<br> <xs:complexType>
<br> <xs:complexContent>
<br> <xs:extension base="xs:annotated">
<br> <xs:attribute name="xpath" use="required">
<br> <xs:simpleType>
<br> <xs:documentation>A subset
<br>in selectors</xs:documentation>
<br> <xs:documentation>A utility
<br>use</xs:documentation>
<br> <xs:restriction base="xs:token">
<br> <xs:documentation>The
following pattern is intended to allow XPath
<br>
<br> Selector
<br> Path
<br> Step
::= '.' | NameTest
<br> NameTest
<br>
<br> </xs:documentation>
<br> <xs:pattern value="<font color="#3333FF"> (\.//)?(((child::)?((\i\c*:)?(\i\c*|\*)))|\.)(/(((child::)?( (\i\c*:)?(\i\c*|\*)))|\.))*(\|(\.//)?(((child::)?((\i\c*:)?( \i\c*|\*)))|\.)(/(((child::)?((\i\c*:)?(\i\c*|\*)))|\.))*)* </font>">
<br> </xs:pattern>
<br> </xs:restriction>
<br> </xs:simpleType>
<br> </xs:attribute>
<br> </xs:extension>
<br> </xs:complexContent>
<br> </xs:complexType>
<br> </xs:element></blockquote>
ignore spaces, but I think the XSD model's strictness is "more correct."
Removing the spaces from the expression does eliminate the error message.
Okay?
<br>
<p>Guy Sharon wrote:
<blockquote TYPE=CITE>I applied a 'unique' constraint on an element an
<br>message (in the IDE) for the attribute 'xpath' of the 'selector' element
<br>when the value is:
<br>myNS:elem1 | myNS:elem2
<p>When I use the same schema with all the feature of validation with the
<br>xerces parser I don't get an error message and the parser does detect
when
<br>the constraint is broken.
<p>The schema also passes validation with IBM's SQC</blockquote>
</html>
--------------58F52F675882AE5CE18516A1--
Re: XPath pattern error [message #575472 is a reply to message #25941] |
Guy,
<xs:annotation>
<xs:documentation
</xs:annotation>
<xs:complexType>
<xs:complexContent>
<xs:simpleType>
<xs:annotation>
</xs:annotation>
<xs:annotation>
allow XPath
</xs:documentation>
</xs:annotation>
<xs:pattern
</xs:pattern>
</xs:restriction>
</xs:simpleType>
</xs:attribute>
</xs:extension>
</xs:complexType>
</xs:element>
> when the value is:
<html>
Guy,
<br>
<br> Selector
<br> Path
<br> Step
::= '.' | NameTest
<br> NameTest
<br>
<br> </xs:pattern>
Okay?
<br>
when
</html>
FUDForum. Page generated in 0.04246 seconds
