Home » Archived » BIRT » Values in dataset to be used as input for another dataset
Values in dataset to be used as input for another dataset [message #261986] Fri, 23 November 2007 04:09 Go to next message
Originally posted by: alpc.geo.yahoo.com
Is there a way to use some values from 1 dataset (which returns only 1 row
of data) to be used as input for another dataset? The required values from
the 1st dataset does not appear on the report, therefore, I could not
follow what was shown in subreport example.
E.g. 1st dataset returns DocNo and Date. I want to be able to use DocNo as
an input for 2nd dataset.
The report builder is confined to 2.1.0 version.
Re: Values in dataset to be used as input for another dataset [message #262455 is a reply to message #261986] Fri, 30 November 2007 03:34 Go to previous messageGo to next message
Er, anyone? No one is able to help in this?
Re: Values in dataset to be used as input for another dataset [message #262465 is a reply to message #262455] Fri, 30 November 2007 09:02 Go to previous messageGo to next message
Originally posted by: stuart.roe.ovic.co.uk
Can you use a Joint Data Set?
Re: Values in dataset to be used as input for another dataset [message #262530 is a reply to message #262465] Mon, 03 December 2007 03:03 Go to previous messageGo to next message
I doubt this is possible. For 1, the value needed is part of the dataset
that is fetched based on the 1st requirement. 2, Both of the datasets are
using stored procedures on the database for retrieval.
How do you use a joint data set in this case?
Re: Values in dataset to be used as input for another dataset [message #262532 is a reply to message #262465] Mon, 03 December 2007 03:08 Go to previous messageGo to next message
I am trying to see if I could use global variable - set the variable after
the retrieval of data of 1st dataset, and then before opening the 2nd
dataset, set the parameter of 2nd dataset to the global variable.
However, I am having some issues with my scripting and well, being rather
new to BIRT, I am struggling to figure out how to do this (or resolve the
scripting issue).
Re: Values in dataset to be used as input for another dataset [message #262576 is a reply to message #262532] Mon, 03 December 2007 17:02 Go to previous messageGo to next message
Originally posted by: johnw.innoventsolutions.com
--------------090504010902020909000404
Yes, you can use a "value" from a query to drive another query. Results
aren't actually retrieved until a bound element is called int he report
generation. If you create a table with the outer query, and in one of
the detail rows, embed the inner query, you can use the the onRender of
the outer table to set the parameter. I have attached a report design
that demonstrated this. Look at the onRender method for the table.
> after the retrieval of data of 1st dataset, and then before opening the
> 2nd dataset, set the parameter of 2nd dataset to the global variable.
> rather new to BIRT, I am struggling to figure out how to do this (or
> resolve the scripting issue).
Content-Type: text/xml;
name="Image on Last Page.rptdesign"
Content-Disposition: inline;
filename="Image on Last Page.rptdesign"
<report xmlns="http://www.eclipse.org/birt/2005/design" version="3.2.15" id="1">
<property name="createdBy">Eclipse BIRT Designer Version 2.2.1.r22a_v20071101 Build &lt;2.2.1.v20071101-1439></property>
<property name="units">in</property>
<property name="comments">Copyright (c) 2007 &lt;&lt;Your Company Name here>></property>
<html-property name="description">Creates a blank report with no predefined content.</html-property>
<text-property name="displayName">Blank Report</text-property>
<property name="iconFile">/templates/blank_report.gif</property>
<parameters>
<scalar-parameter name="param_1" id="47">
<property name="valueType">static</property>
<property name="dataType">integer</property>
<property name="paramType">simple</property>
<property name="isRequired">true</property>
<property name="controlType">text-box</property>
<property name="distinct">true</property>
<structure name="format">
<property name="category">Unformatted</property>
</structure>
</scalar-parameter>
</parameters>
<data-sources>
<oda-data-source extensionID="org.eclipse.birt.report.data.oda.jdbc" name="Data Source" id="44">
<property name="odaDriverClass">org.eclipse.birt.report.data.oda.sampledb.Driver </property>
<property name="odaURL">jdbc:classicmodels:sampledb</property>
<property name="odaUser">ClassicModels</property>
</oda-data-source>
</data-sources>
<data-sets>
<oda-data-set extensionID="org.eclipse.birt.report.data.oda.jdbc.JdbcSelectDataSet " name="CustomerTable" id="45">
<structure name="cachedMetaData">
<list-property name="resultSet">
<structure>
<property name="position">1</property>
<property name="name">CUSTOMERNUMBER</property>
</structure>
<structure>
<property name="position">2</property>
<property name="name">CUSTOMERNAME</property>
<property name="dataType">string</property>
</structure>
</list-property>
</structure>
<property name="dataSource">Data Source</property>
<structure>
<property name="nativeName">CUSTOMERNUMBER</property>
<property name="nativeDataType">4</property>
</structure>
<structure>
<property name="nativeName">CUSTOMERNAME</property>
<property name="nativeDataType">12</property>
</structure>
</list-property>
<property name="queryText">select CLASSICMODELS.CUSTOMERS.CUSTOMERNUMBER,
CLASSICMODELS.CUSTOMERS.CUSTOMERNAME
from CLASSICMODELS.CUSTOMERS</property>
<xml-property name="designerValues"><![CDATA[<?xml version="1.0" encoding="UTF-8"?>
<model:DesignValues xmlns:design="http://www.eclipse.org/datatools/connectivity/oda/design" xmlns:model="http://www.eclipse.org/birt/report/model/adapter/odaModel">
<Version>1.0</Version>
<design:ResultSets derivedMetaData="true">
<design:resultSetDefinitions>
<design:resultSetColumns>
<design:resultColumnDefinitions>
<design:attributes>
<design:name>CUSTOMERNUMBER</design:name>
<design:position>1</design:position>
<design:nativeDataTypeCode>4</design:nativeDataTypeCode>
<design:precision>10</design:precision>
<design:scale>0</design:scale>
<design:nullability>Nullable</design:nullability>
</design:attributes>
<design:usageHints>
<design:label>CUSTOMERNUMBER</design:label>
<design:formattingHints>
<design:displaySize>11</design:displaySize>
</design:formattingHints>
</design:usageHints>
</design:resultColumnDefinitions>
<design:attributes>
<design:name>CUSTOMERNAME</design:name>
<design:position>2</design:position>
<design:nativeDataTypeCode>12</design:nativeDataTypeCode>
<design:precision>50</design:precision>
<design:usageHints>
<design:label>CUSTOMERNAME</design:label>
<design:displaySize>50</design:displaySize>
</design:resultSetColumns>
</design:resultSetDefinitions>
</design:ResultSets>
</model:DesignValues>]]></xml-property>
</oda-data-set>
<oda-data-set extensionID="org.eclipse.birt.report.data.oda.jdbc.JdbcSelectDataSet " name="OrderTable" id="46">
<structure>
<property name="name">ORDERNUMBER</property>
</structure>
</list-property>
</structure>
<list-property name="parameters">
<structure>
<property name="name">param_1</property>
<property name="paramName">param_1</property>
<property name="nativeName"></property>
<property name="isOptional">false</property>
<property name="isInput">true</property>
<property name="isOutput">false</property>
</structure>
</list-property>
<structure>
<property name="nativeName">ORDERNUMBER</property>
</structure>
</list-property>
<property name="queryText">select CLASSICMODELS.ORDERS.ORDERNUMBER
from CLASSICMODELS.ORDERS
where
CLASSICMODELS.ORDERS.CUSTOMERNUMBER = ?</property>
<design:DataSetParameters>
<design:parameterDefinitions>
<design:inOutMode>In</design:inOutMode>
<design:attributes>
<design:name></design:name>
<design:nullability>Unknown</design:nullability>
<design:uiHints/>
<design:inputAttributes>
<design:elementAttributes>
<design:optional>false</design:optional>
<design:masksValue>false</design:masksValue>
<design:uiHints>
<design:promptStyle>TextField</design:promptStyle>
</design:uiHints>
</design:elementAttributes>
</design:inputAttributes>
</design:parameterDefinitions>
</design:DataSetParameters>
<design:attributes>
<design:name>ORDERNUMBER</design:name>
<design:usageHints>
<design:label>ORDERNUMBER</design:label>
</oda-data-set>
</data-sets>
<page-setup>
<simple-master-page name="Simple MasterPage" id="2"/>
</page-setup>
<body>
<table id="48">
<property name="height">1.5416666667in</property>
<property name="width">5.4166666667in</property>
<property name="dataSet">CustomerTable</property>
<list-property name="boundDataColumns">
<structure>
<expression name="expression">dataSetRow["CUSTOMERNUMBER"]</expression >
</structure>
<structure>
<expression name="expression">dataSetRow["CUSTOMERNAME"]</expression >
</structure>
</list-property>
<column id="62">
<property name="width">2.4166666667in</property>
</column>
<column id="63">
<property name="width">3in</property>
</column>
<header>
<row id="49">
<cell id="50"/>
<cell id="52"/>
</row>
</header>
<detail>
<row id="54">
<method name="onRender"><![CDATA[params["param_1"] = row["CUSTOMERNUMBER"]]]></method>
<cell id="55">
<data id="58">
<property name="resultSetColumn">CUSTOMERNAME</property>
</data>
</cell>
<cell id="57"/>
</row>
<row id="64">
<cell id="65"/>
<cell id="66">
<table id="67">
<property name="width">100%</property>
<property name="dataSet">OrderTable</property>
<structure>
<expression name="expression">dataSetRow["ORDERNUMBER"]</expression >
</structure>
</list-property>
<column id="76"/>
<header>
<row id="68">
<cell id="69"/>
</row>
</header>
<detail>
<row id="71">
<cell id="72">
<data id="73">
<property name="resultSetColumn">ORDERNUMBER</property>
</data>
</cell>
</row>
</detail>
<footer>
<row id="74">
<cell id="75"/>
</row>
</footer>
</table>
</cell>
</row>
</detail>
<footer>
<row id="59">
<cell id="60"/>
<cell id="61"/>
</row>
</footer>
</table>
</body>
</report>
--------------090504010902020909000404--
Re: Values in dataset to be used as input for another dataset [message #262585 is a reply to message #262576] Mon, 03 December 2007 21:19 Go to previous messageGo to next message
Hi John,
Thanks. I am trying to view the report design but I am getting some error
on the xml source - unhandled event loop exception and
java.lang.nullpointerexception error - so it will take awhile to figure
out how you do it.
Re: Values in dataset to be used as input for another dataset [message #262600 is a reply to message #262585] Tue, 04 December 2007 01:47 Go to previous message
A. L. wrote:
>> Results aren't actually retrieved until a bound element is called int
>> he report generation. If you create a table with the outer query, and
>> in one of the detail rows, embed the inner query, you can use the the
>> onRender of the outer table to set the parameter. I have attached a
>> report design that demonstrated this. Look at the onRender method for
>> the table.
> Hi John,
> error on the xml source - unhandled event loop exception and
> out how you do it.
To help out, what I did in that report is I embedded the table
outputting one data set into a parent table for the driving data set. In
the onRender method (the onCreate method could be used also), I set a
global parameter which is set to hidden and not required, using the
following script:
where param_1 is a report parameter that is bound to my child dataset,
and CUSTOMERNUMBER is a foreign key in the child table. Now, the outer
table, which displays a list of customers, will populate the current
customer number into the child table.
There are several different ways to do this similar task, but this is
probably the easiest.
John
Previous Topic:Caching Problem
Next Topic:Can we provide a datepicker or calender option to a parameter
Current Time: Sun Oct 26 06:58:33 EDT 2025
Powered by FUDForum. Page generated in 0.51584 seconds
