SFSB [message #25938] |
Thu, 14 May 2009 03:29  |
is there already a way in riena communication to hold something like a
statefull session bean on the server side? I need a none-jdbc connection
to a backend that can be started and stopped for a session (client
login) and I would like to implement it on the server side.
Rüdiger
Re: SFSB [message #26102 is a reply to message #26061] |
Thu, 14 May 2009 06:17  |
ekke schrieb:
>>>> a statefull session bean on the server side? I need a none-jdbc
>>>> connection to a backend that can be started and stopped for a
>>>> session (client login) and I would like to implement it on the
>>>> server side.
>>>> Rüdiger
>>> rüdiger,
>>> you can use EasyBeans OSGI EJB3 Container if you need Stateful or
>>> Stateless Session Beans.
>>> EasyBeans provides OSGI Services for your Business Interfaces to SLSB
>>> or SFSB, which you then can use vie Riena as Riena Remote Services.
>>> Don't know if this is what you're looking for
>>> ekke
>> Hi ekke,
>> you are right, that could it be. But I'm waiting for your server so
>> long and for me I was not able to solve all that problems to get a
>> running system around riena and ezb. You would make me a lucky man if
>> I could have a look in your solution.
>> rüdiger
> I'm also waiting so long for my server ;-)
> but there was some progress :-)
> end of may redView (redview.org) will be published
> (this will not help you - its the Business-UI-part)
> and begin of july my server will be published
> (open-erp-ware.org)
> ...sorry - not earlier possible
> ekke
hi ekke,
that should not be seen as a reproach. I'm tracing your hard work and
thanking for what you do to the community. And what you are creating is
exactly that fulfilling my needs. I will wait.
rüdiger
Re: SFSB [message #582470 is a reply to message #25938] |
Thu, 14 May 2009 04:01  |
> Rüdiger
rüdiger,
EasyBeans provides OSGI Services for your Business Interfaces to SLSB or
ekke
Re: SFSB [message #582484 is a reply to message #25981] |
Thu, 14 May 2009 05:19  |
>> connection to a backend that can be started and stopped for a session
>> (client login) and I would like to implement it on the server side.
>> Rüdiger
> rüdiger,
> ekke
Hi ekke,
you are right, that could it be. But I'm waiting for your server so long
and for me I was not able to solve all that problems to get a running
system around riena and ezb. You would make me a lucky man if I could
rüdiger
Re: SFSB [message #582501 is a reply to message #26021] |
Thu, 14 May 2009 05:50  |
>>> Rüdiger
>> rüdiger,
>> ekke
> Hi ekke,
> rüdiger
(open-erp-ware.org)
....sorry - not earlier possible
ekke
Re: SFSB [message #582511 is a reply to message #26061] |
>>>> server side.
>>>> Rüdiger
>>> rüdiger,
>>> ekke
>> Hi ekke,
>> rüdiger
> (open-erp-ware.org)
> ekke
hi ekke,
rüdiger
FUDForum. Page generated in 0.05689 seconds
