Home » Archived » BIRT » Report Parameters - Dataset result used in another report parameter
Report Parameters - Dataset result used in another report parameter [message #261977] Thu, 22 November 2007 22:07 Go to next message
Originally posted by: alpc.geo.yahoo.com
Hi. I am new to BIRT and am trying create a report with 3 Report
Parameters. 1 static parameter which the user will enter. Based on this
parameter, report parameter 2 would have a list (from a dataset, in
combobox form) for the user to select, and based on both report parameter
1 & 2, report parameter 3 would have a list (from another dataset, in
combobox form) for user to select.
I have tried using static parameter for parameter 1, cascading parameters
for 2 & 3. However, it seems that parameter 2 & 3 does not gets updated
when the parameters are updated with the values.
I cannot find the "Link to Report Parameter" in the Dataset "Edit ->
Parameters" properties. I can only add the report parameter as default
value.
By the way, the 2 datasets are calling stored procedures in the database.
Finally, I am being confined to BIRTH 2.1.0 version (due to compatibility
with current report template).
Would appreciate some help in getting this report to work.
Thanks!
Re: Report Parameters - Dataset result used in another report parameter [message #262459 is a reply to message #261977] Fri, 30 November 2007 03:35 Go to previous message
Er, no one?
Previous Topic:XML Data source & linked tables
Next Topic:Rendering node lists.
Current Time: Tue Jul 22 02:39:07 EDT 2025
Powered by FUDForum. Page generated in 0.05727 seconds
