Home » Archived » BIRT » TOC in pdf
TOC in pdf [message #261729] Tue, 20 November 2007 03:34 Go to next message
Originally posted by: firstname.lastname.napa.fi
Hi!
I'm almost certain that I have seen example java code for producing a
table of contents for a birt report rendered as pdf using itext. I googled
and googled and could not find it - any clues where it might be?
-Antti-
Re: TOC in pdf [message #261876 is a reply to message #261729] Wed, 21 November 2007 10:23 Go to previous messageGo to next message
Antti,
The TOC is built in the designer and will automatically be seen in a pdf
that is generated in pdf. Is this not what you are looking for?
Jason
Antti Karanta wrote:
> Hi!
> googled and googled and could not find it - any clues where it might be?
> -Antti-
Re: TOC in pdf [message #261935 is a reply to message #261876] Thu, 22 November 2007 01:38 Go to previous messageGo to next message
On Wed, 21 Nov 2007 17:23:41 +0200, Jason Weathersby
No, that builds bookmarks that are shown on the left in acrobat reader.
Those are not part of the document itself (e.g. when printed). What I was
looking for was ability to have those same items as a book style TOC in
the beginning of the pdf, i.e. an enumeration of TOC entries w/
corresponding page numbers.
-Antti-
>> Hi!
>> a table of contents for a birt report rendered as pdf using itext. I
>> -Antti-
Re: TOC in pdf [message #262054 is a reply to message #261935] Mon, 26 November 2007 10:07 Go to previous message
Antti,
I am not sure how to do this, but you should be able to add the itext
jars within the itext plugin to your build path and write code using
them in an application that uses the REAPI.
Jason
>> pdf that is generated in pdf. Is this not what you are looking for?
> reader. Those are not part of the document itself (e.g. when printed).
> What I was looking for was ability to have those same items as a book
> style TOC in the beginning of the pdf, i.e. an enumeration of TOC
> entries w/ corresponding page numbers.
> -Antti-
>>> Hi!
>>> producing a table of contents for a birt report rendered as pdf using
>>> itext. I googled and googled and could not find it - any clues where
>>> it might be?
>>> -Antti-
Previous Topic:How to create a custom chart type
Next Topic:How to convert NULL values from DB to ""?
Current Time: Mon Nov 17 14:19:37 EST 2025
Powered by FUDForum. Page generated in 0.33358 seconds
