"Available Software" Install disabled [message #261254] |
Wed, 16 July 2008 14:39 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: breaux.us.ibm.com
I have installed the base Java IDE package of 3.4, and I'm trying to add
some additional components. However, no matter which I select, the
"Install..." button and menu items remain greyed-out/disabled. What
obvious step am I missing here?
Re: "Available Software" Install disabled [message #261270 is a reply to message #261263] |
Wed, 16 July 2008 17:04 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Nick Boldt wrote:
> "installed" == "unpacked with something other than the built-in Windows
> unzip tool?
Yes, Winzip.
> What version of Java are you using to start Eclipse? Chances are you
> need 5.0+.
Both Sun Java 6 and IBM Java 6.
> Did you select some items in the view before trying to click "Install..." ?
Yes
> Nick
Will check the other references too. I actually manually added an
external plugin site, and the Install button was enabled for that one.
It's possible, though, that the items listed are all already installed?
In particular, I installed the base Java package and am trying to add WTP.
As far as I can tell, both from the list of installed features and from
trying to open web artifacts, WTP doesn't appear to be installed yet, but
perhaps it is?
FUDForum. Page generated in 0.08212 seconds
