Home » Archived » BIRT » Report Updates with timer
Report Updates with timer [message #261090] Fri, 09 November 2007 14:48
Hello!
We started a Reporting Project for Automation Components checking if
they are OK! This Automation components sending their status over OPC
DCOM Server!
We want to use BIRT with Eclipe RCP to do this!
So I have two questions:
1) Does anybody know an OPC DCom Client for Java which can be used with
ODA Extension?
2) Is there an easy possibility to use a timer object to generate a
report e.g. every 10 seconds (get the new values of the componente and
check the status)?
Thanks a lot for every information!
chris
Previous Topic:Integer parameter not working in 2.2.1.1?
Next Topic:How do I format data in hexadecimal?
Current Time: Wed Oct 22 18:11:16 EDT 2025
Powered by FUDForum. Page generated in 0.03128 seconds
