Home » Newcomers » Newcomers » Unable to update eclipse plugin
Unable to update eclipse plugin [message #261036] |
Mon, 14 July 2008 10:24  |
Originally posted by: martin.renaud.imagemsoft.com
Hi Experts,
i'm trying to update plugins on Eclipse Ganymede (which i used since a fews
days only). Everytime i tryied to update, i got an error message. In this
example, i'm trying to update mylyn 2.xx to 3.xx
Here a part of the message:
"Cannot complete the request. See the details.
Mylyn Bridge: Eclipse IDE is already installed, so an update will be
performed instead.
Mylyn Connector: Bugzilla is already installed, so an update will be
performed instead.
Mylyn Bridge: Java Development is already installed, so an update will be
performed instead.
Mylyn Task List (Required) is already installed, so an update will be
performed instead.
Mylyn Focused UI (Recommended) is already installed, so an update will be
performed instead.
Cannot find a solution where both Match[requiredCapability:
osgi.bundle/org.eclipse.wst.validation/[1.1.0,1.2.0)] and
osgi.bundle/org.eclipse.wst.validation/[1.2.0,2.0.0)] can be satisfied.
osgi.bundle/org.eclipse.jst.common.project.facet.core/[1.1.0 ,1.2.0)] and
osgi.bundle/org.eclipse.jst.common.project.facet.core/[1.3.0 ,2.0.0)] can be
satisfied.
osgi.bundle/org.eclipse.ui/[3.4.0,4.0.0)] and Match[requiredCapability:
osgi.bundle/org.eclipse.ui/[3.2.0,3.4.0)] can be satisfied.
osgi.bundle/org.eclipse.core.resources/[3.4.0,4.0.0)] and
osgi.bundle/org.eclipse.core.resources/[3.2.0,3.4.0)] can be satisfied.
osgi.bundle/org.eclipse.ui.ide/[3.4.0,4.0.0)] and Match[requiredCapability:
osgi.bundle/org.eclipse.ui.ide/[3.3.0,3.4.0)] can be satisfied.
osgi.bundle/org.eclipse.wst.common.project.facet.core/[1.3.0 ,2.0.0)] and
osgi.bundle/org.eclipse.wst.common.project.facet.core/[1.2.1 ,1.3.0)] can be
satisfied.
osgi.bundle/org.eclipse.ui.workbench.texteditor/[3.4.0,4.0.0 )] and
osgi.bundle/org.eclipse.ui.workbench.texteditor/[3.2.0,3.4.0 )] can be
satisfied. (...)"
what's wrong!
thks
Re: Unable to update eclipse plugin [message #261039 is a reply to message #261036] |
Mon, 14 July 2008 10:40   |
Originally posted by: codeslave.ca.ibm.com
Looks like you're trying to update WTP as well as Mylyn, and for some
reason it won't let you. You might have to uninstall WTP and reinstall
it, or try updating Mylyn separately from WTP.
Or, maybe you unpacked Eclipse 3.4 on top of Eclipse 3.3? You need to
install Eclipse 3.4 in a fresh directory, NOT in the same place as 3.3.
Nick
martin.renaud wrote:
> Hi Experts,
> fews days only). Everytime i tryied to update, i got an error message.
> In this example, i'm trying to update mylyn 2.xx to 3.xx
> performed instead.
> performed instead.
> be performed instead.
> performed instead.
> be satisfied.
> Match[requiredCapability: osgi.bundle/org.eclipse.ui.ide/[3.3.0,3.4.0)]
> can be satisfied.
> be satisfied.
> satisfied. (...)"
> what's wrong!
> thks
Nick Boldt :: Release Engineer, IBM Toronto Lab
Eclipse Modeling :: http://www.eclipse.org/modeling
http://wiki.eclipse.org/index.php/User:Nickb
Re: Unable to update eclipse plugin [message #261077 is a reply to message #261069] |
Mon, 14 July 2008 13:37  |
>> Hi Experts,
> That doesn't make sense; Ganymede already includes Mylyn 3.0, not 2.x.
> Eric
Yeah i know,
but in the about screen, it's indicate Mylyn version 2.1.0... not 3.xx
I'm going to follow the suggestion of Nick:
"Looks like you're trying to update WTP as well as Mylyn, and for some
it, or try updating Mylyn separately from WTP."
Current Time: Sat Jul 12 15:52:32 EDT 2025
Powered by FUDForum. Page generated in 0.09205 seconds
