Home » Eclipse Projects » Eclipse Platform » Need help with binding Cntl-l to recenter as in emacs
Need help with binding Cntl-l to recenter as in emacs [message #260943] Mon, 12 July 2004 19:58 Go to next message
Originally posted by: h3nqh8v02.sneakemail.com
Hi All,
I'm a long-time emacs and new eclipse user. I'm very impressed so far.
I have set up eclipse (Version 3.0.0, Build id 200406192000) to use the
emacs key bindings. Yet when editing text or Java code my brainstem
expects Cntl-l (i.e. control + lowercase l) to result in a "recentering"
of the text view so that the current line is in the center of the screen.
This is what the default binding for Cntl-l in emacs, the recenter
command, does. I have tried to find an analogous command in eclipse (by
browsing through commands in Window->Preferences->Keys) so I can bind it
to Cntl-l, but to no avail.
Does eclipse have a recenter command? Any tips?
David
Re: Need help with binding Cntl-l to recenter as in emacs [message #261070 is a reply to message #260943] Tue, 13 July 2004 06:26 Go to previous messageGo to next message
It does not.
-tom
Re: Need help with binding Cntl-l to recenter as in emacs [message #261534 is a reply to message #261070] Wed, 14 July 2004 13:50 Go to previous messageGo to next message
> It does not.
Thanks. Guess it's time to figure out how to make a feature request...
David
Re: Need help with binding Cntl-l to recenter as in emacs [message #261774 is a reply to message #261534] Thu, 15 July 2004 10:23 Go to previous message
>>It does not.
http://bugs.eclipse.org/bugs
Previous Topic:Plugin Test with JUnit
Next Topic:order of extension point query results
Current Time: Fri Jul 18 17:08:23 EDT 2025
Powered by FUDForum. Page generated in 0.03710 seconds
