Home » Newcomers » Newcomers » How do I remove a directory from CVS using Eclipse
How do I remove a directory from CVS using Eclipse [message #260657] Thu, 10 July 2008 11:19 Go to next message
I'm using Eclipse 3.4. I know how to delete a directory in the package
explorer view, but I don't know how to indicate to CVS that I want this
directory removed and tag appropriately?
Anyone know how this is done?
thanks, - Dave
Re: How do I remove a directory from CVS using Eclipse [message #260661 is a reply to message #260657] Thu, 10 July 2008 11:39 Go to previous messageGo to next message
Dave,
I think that CVS doesn't really let you delete directories. When I've
wanted to delete a directory, I've had to go into the actual file system
of the repository where CVS maintains the files and delete it that way...
Dave Alvarado wrote:
> package explorer view, but I don't know how to indicate to CVS that I
> want this directory removed and tag appropriately?
> thanks, - Dave
Re: How do I remove a directory from CVS using Eclipse [message #260681 is a reply to message #260661] Thu, 10 July 2008 15:36 Go to previous message
Originally posted by: codeslave.ca.ibm.com
If you delete a folder in Eclipse and then synch up those changes in the
Synchronize view, the files will be "deleted" in CVS, which means "moved
into a subfolder called 'Attic', in case you want to bring them back."
Ad Ed says, to actually delete, you have to ssh to the cvs server and
`rm -fr` the folder.
Ed Merks wrote:
> Dave,
>> thanks, - Dave
Nick Boldt :: Release Engineer, IBM Toronto Lab
Eclipse Modeling :: http://www.eclipse.org/modeling
http://wiki.eclipse.org/index.php/User:Nickb
Previous Topic:Trouble Importing
Next Topic:ANT wont run in eclipse on Mac OS X
Current Time: Tue Jul 22 00:01:05 EDT 2025
Powered by FUDForum. Page generated in 0.28258 seconds
