Home » Newcomers » Newcomers » Getting 'taglib directive for "f" does not exist or TLD is not found'
Getting 'taglib directive for "f" does not exist or TLD is not found' [message #260532] Wed, 09 July 2008 11:56 Go to next message
I'm using Eclipse 3.4 and when I open my JSF page in Eclipse, I'm getting
red "x"'s next to my JSF directives. For example,
<f:view>
has a red "x" along the left margin and when I roll over it, it gives me
the error, 'taglib directive for "f" does not exist or TLD is not found.'
This is odd because I have the appropriate directives, including
<%@ taglib uri="http://java.sun.com/jsf/core" prefix="f" %>
at the top of my page. Strangely, the "<%@" portion appears in red. Does
anyone know how I can get Eclipse to recognize the listed directives?
Thanks, - Dave
Re: Getting 'taglib directive for "f" does not exist or TLD is not found' [message #260561 is a reply to message #260532] Wed, 09 July 2008 14:41 Go to previous messageGo to next message
Originally posted by: cmattmiller.gmail.com
I had the same problem a couple of times. I just rewrote the line and it
was fine. But to be sure, do you have jstl.jar in the build path?
Re: Getting 'taglib directive for "f" does not exist or TLD is not found' [message #260646 is a reply to message #260561] Thu, 10 July 2008 10:23 Go to previous messageGo to next message
Thanks for your reply. When I right click on my project, select
"Properties", click the "Libraries" tab, jstl-1.1.0.jar - (directory it is
in) appears. But beneath it read
Source Attachment: (none)
Javadoc location: (None)
Native Library Location: (None)
Access rules: (No restrictions)
Not sure if these are problematic or not. When you mentioned you rewrote
the '<%@ taglib uri="http://java.sun.com/jsf/core" prefix="f" %>' line,
how did you rewrite it?
Thanks again, - Dave
Re: Getting 'taglib directive for "f" does not exist or TLD is not found' [message #260649 is a reply to message #260646] Thu, 10 July 2008 10:47 Go to previous messageGo to next message
K, I just looked and I also have it in a WEB-INF/lib folder.
I just retyped it on the next line.
Re: Getting 'taglib directive for "f" does not exist or TLD is not found' [message #261209 is a reply to message #260646] Wed, 16 July 2008 01:03 Go to previous messageGo to next message
> is in) appears. But beneath it read
> rewrote the '<%@ taglib uri="http://java.sun.com/jsf/core" prefix="f"
> %>' line, how did you rewrite it?
JSTL and JSF aren't provided by the same jars, are they?
Nitin Dahyabhai
Eclipse WTP Source Editing
IBM Rational
Re: Getting 'taglib directive for "f" does not exist or TLD is not found' [message #261248 is a reply to message #261209] Wed, 16 July 2008 09:58 Go to previous message
No they aren't...my bad. There is a separate jsf-api.jar
Previous Topic:WS02 and Eclipse WTP
Next Topic:EPP & UDC
Current Time: Mon Jul 14 22:45:39 EDT 2025
Powered by FUDForum. Page generated in 0.09870 seconds
