How to set parameters to PIE Chart Instead of DataSet [message #260525] |
Mon, 05 November 2007 01:20  |
Originally posted by: naresh1710.rediff.com
Hi All
I have a problem with Pie chart,
in my dataset am getting the value like 2,3,4
but all these are in different columns,if all these
are in a same column then we can drag that column,
but all these are single values(count),and diff columns,
how to achieve this one....
Please tell me asap.....
Naresh.T
Re: How to set parameters to PIE Chart Instead of DataSet [message #260778 is a reply to message #260753] |
Tue, 06 November 2007 04:16  |
You can use the sql union keyword to merge the rows into one column (if
there is one value per row).
David
"Naresh" <naresh1710@rediff.com> wrote in message
news:8c670a5878a5e404ab2b0a653b2a8544$1@www.eclipse.org...
> Hi David
> Thank you for your reply, Actually i tried like that but in sql querry
> i had given with select(count), select(count)...
> Then i got like columns not in rows, thats why i asked about this.If
> you have any other idea in sql please help me
> how to do this.
> Thanks Naresh
FUDForum. Page generated in 0.05326 seconds
