Home » Archived » BIRT » BIRT 2.2.1 birt-viewer/frameset?__report= and birt-viewer/run?__report= fail to display charts
BIRT 2.2.1 birt-viewer/frameset?__report= and birt-viewer/run?__report= fail to display charts [message #260484] Sat, 03 November 2007 13:12 Go to next message
Originally posted by: john.johnhornsby.me.uk
In BIRT 2.2.1 neither birt-viewer/frameset?__report= or
birt-viewer/frameset?__report= show charts as I have seen in previous
versions. They both reports with tables of data OK, but nothing for
charts.
I see that the charts are in fact produced on disk and they appear to be
referenced in the HTML that's produced with a reference to a certain
birt-viewer/preview?__imageID=.
The problem is that the preview servlet doesn't appear to be working or
present ? I don't see any servlet-mapping in the web.xml or indeed any
class in the jar containing the other servlets that might be the one to
handle preview.
How do I fix this problem?
John Hornsby
Re: BIRT 2.2.1 birt-viewer/frameset?__report= and birt-viewer/run?__report= fail to display charts [message #260658 is a reply to message #260484] Mon, 05 November 2007 12:20 Go to previous messageGo to next message
John,
Can you enable logging in the web.xml and post the log file?
This works in my installation. What app server are you using?
Jason
John Hornsby wrote:
> charts.
> handle preview.
> Thanks
> John Hornsby
Re: BIRT 2.2.1 birt-viewer/frameset?__report= and birt-viewer/run?__report= fail to display charts [message #260805 is a reply to message #260658] Tue, 06 November 2007 07:42 Go to previous messageGo to next message
Hi Jason,
I'm using tomcat 5.5.17.
I switched the logging on and have attached the log file.
I've also attached the html that is returned which refers to the /preview
servlet and references the image that has been created. Actually it gets
the name right but it's generated in:
birt-viewer\report\images\16B95ED13E4572D77482DB5B05B1E6A7
so it isn't found.
Any help much appreciated.
John
"Jason Weathersby" <jasonweathersby@alltel.net> wrote in message
news:fgnj7n$c8j$1@build.eclipse.org...
> John,
> Jason
> John Hornsby wrote:
>> charts.
>> handle preview.
>> Thanks
>> John Hornsby
Re: BIRT 2.2.1 birt-viewer/frameset?__report= and birt-viewer/run?__report= fail to display charts [message #260823 is a reply to message #260805] Tue, 06 November 2007 09:16 Go to previous messageGo to next message
John,
The preview operation should have a mapping at the bottom of the web.xml
<servlet-mapping>
<servlet-name>EngineServlet</servlet-name>
<url-pattern>/preview</url-pattern>
</servlet-mapping>
Does this exist in your web.xml?
Also is your image directory been changed in your web.xml?
<context-param>
<param-name>BIRT_VIEWER_IMAGE_DIR</param-name>
<param-value></param-value>
</context-param>
Jason
John Hornsby wrote:
> Hi Jason,
> so it isn't found.
> John
>> John,
>> Jason
>> John Hornsby wrote:
>>> Hi,
>>> charts.
>>> handle preview.
>>> Thanks
>>> John Hornsby
> Chart of Total Number of Orders in the Last 30 Days
Re: BIRT 2.2.1 birt-viewer/frameset?__report= and birt-viewer/run?__report= fail to display charts [message #260845 is a reply to message #260823] Tue, 06 November 2007 10:57 Go to previous message
Hi Jason,
Yes, the problem was the mising /preview mapping.
Once I added that it all worked fine.
I can only imagine I did not upgrade correctly.
John
news:fgpspq$cuv$1@build.eclipse.org...
> John,
> <servlet-mapping>
> </servlet-mapping>
> <context-param>
> </context-param>
> Jason
> John Hornsby wrote:
>> Hi Jason,
>> gets the name right but it's generated in:
>> so it isn't found.
>> John
>>> John,
>>> Jason
>>> John Hornsby wrote:
>>>> Hi,
>>>> charts.
>>>> be
>>>> any
>>>> handle preview.
>>>> Thanks
>>>> John Hornsby
Previous Topic:1. Page Number is not coming properly in HTML format
Next Topic:Charting a data cube
Current Time: Fri Jul 18 05:26:04 EDT 2025
Powered by FUDForum. Page generated in 0.09315 seconds
