Please Help - Adding a menu item to a context menu [message #25716] |
Tue, 22 August 2006 09:58  |
Originally posted by: senthil.periasamy.flextronicssoftware.com
I want to add a context menu item in a GMF project.I have developed the
project using the plugin org.eclipse.gmf.map_1.0.0.v20060627-1200.jar
In my project I have created a class in
org.eclipse.examples.mindmap.diagram.providers.mindmapContex tMneuProvider
which extends DiagramContextMenuProvider.and a
MindmapContributionItemProvider which extends
DiagramContributionItemProvider in which I added a menu item.
Also in my plugin.xml i have added the lines
<extension
point=" org.eclipse.gmf.runtime.common.ui.services.action.contributi onItemProviders ">
<contributionItemProvider
class="mindmap.diagram.providers.MindmapContributionItemProvider "
checkPluginLoaded="false">
<Priority name="High"/>
<popupContribution
class=" org.eclipse.gmf.runtime.diagram.ui.providers.MindmapContextM enuProvider ">
<popupMenuGroup id="flexIVR">
</popupMenuGroup>
</popupContribution>
</contributionItemProvider>
</extension>
Even then I am not getting my menu item not added to the context menu.
Also I should add it through code only.
Senthil
FUDForum. Page generated in 0.03087 seconds
