Home » Archived » BIRT » Pass parameters to java script event handlers in charts (ChartEngine)
Pass parameters to java script event handlers in charts (ChartEngine) [message #259944] |
Tue, 30 October 2007 09:43  |
Originally posted by: erdal.karaca.airbus.com
I need to know whether it is possible to pass some arguments to a script
event handler for a given chart object:
Chart chart = ... any chart object
chart.setScript( HistogramEventCallback.class.getName() );
Setting the script for this chart this way makes it impossible to pass
arguments to the executed HistogramEventCallback object without using any
static (class) transfer attributes.
Is there an elegant solution to this problem?
I could write:
class ChartGenerator {
static Map< String, Object > chartProps = new HashMap< String, Object >();
Chart createChart() {
chartProps.put( "data-point-labels", new ArrayList< String >() );
// go on initializing the chart...
class HistogramEventCallback extends ChartEventHandlerAdapter {
public void beforeDrawDataPointLabel( DataPointHints dph, Label label,
IChartScriptContext icsc ) {
if ( ((List)ChartGenerator.chartProps.get( "data-point-labels"
)).isEmpy() ) {
// do something...
As I mentioned this is not elegant, since you have to deal with object
synchronisation etc.
Thanks!
Re: Pass parameters to java script event handlers in charts (ChartEngine) [message #259947 is a reply to message #259944] |
Tue, 30 October 2007 09:50   |
What kind of arguments do you need to pass? Each event function let you
access the IChartScriptContext, which gives you full access to the chart
model. (context.getChartInstance()).
More generally you can create an application context (IExternalContext) and
pass it in the build or prepare method when generating the chart. This will
then be available through IChartScriptContext.getExternalContext(). This can
be used to pass runtime information to the event handler (for instance in a
web app, you could pass session variables).
David
"Erdal Karaca" <erdal.karaca@airbus.com> wrote in message
news:861691e1514e420fbf2ec93f818e664a$1@www.eclipse.org...
> I could write:
> "data-point-labels" )).isEmpy() ) {
> // do something...
> Thanks!
How to pass cutom parameters to java script handler while defining a chart model [message #260016 is a reply to message #259947] |
Wed, 31 October 2007 02:43   |
Thanks!
Unfortunately, I need to pass custom parameters to the chart while
defining the model (i.e. series values, appearance etc.). Building or
rendering the chart is done elsewhere. Hence, it is too late to pass
arguments to the chart object when it is being built or rendered. I would
have to modify the application's architecture to support this ;-(
Maybe one can (mis)use a series' identifier to pass custom parameters
while defining the chart model (Series.setSeriesIdentifier( Object )
expects an object as parameter, so one could pass a Map, or the like). Of
course, this is not elegant as your suggestion...
The following is ugly code but it works:
// while defining your chart model...
Series paramSeries = SeriesImpl.create();
Map< String, Object > props = new HashMap< String, Object >();
props.put( "stddev", new Double( 0.004 ) );
paramSeries.setSeriesIdentifier( props );
sdX.getSeries().add( paramSeries );
//in your script handler...
ChartWithAxes chart = (ChartWithAxes) icsc.getChartInstance();
Axis xAxis = chart.getPrimaryBaseAxes()[ 0 ];
SeriesDefinition sdx =
(SeriesDefinition) xAxis.getSeriesDefinitions().get( 0 );
Series propsSeries = (Series) sdx.getSeries().get( sdx.getSeries().size()
- 1 );
Map< String, Object > props = (Map< String, Object >)
propsSeries.getSeriesIdentifier();
System.out.println( props.get( "stddev" ) );
David Michonneau wrote:
> David
>> I could write:
>> // do something...
>> Thanks!
Re: How to pass cutom parameters to java script handler while defining a chart model [message #260034 is a reply to message #260016] |
Wed, 31 October 2007 05:30   |
I think the way you do it is not really supported and might get broken with
a future BIRT update. Also if you plan to save your chart model to disk at
any time, it will not save this data.
I am not sure why you cannot create a wrapper object containing the chart
model + your parameters. That shouldn't really affect your application
architecture?
David
news:71ee971dd4f84abd6687e05d42528bbb$1@www.eclipse.org...
> Thanks!
> sdx.getSeries().size() - 1 );
>> and pass it in the build or prepare method when generating the chart.
>> This will then be available through
>> IChartScriptContext.getExternalContext(). This can be used to pass
>> runtime information to the event handler (for instance in a web app, you
>> Thanks,
>> David
>>> Hi,
>>> any static (class) transfer attributes.
>>> I could write:
>>> // do something...
>>> Thanks!
Current Time: Mon Jul 14 09:43:25 EDT 2025
Powered by FUDForum. Page generated in 0.63391 seconds
