Compile but the debug doesn't run [message #259900] |
Thu, 03 July 2008 05:30  |
Originally posted by: gabriele.zanetti.ing.unibs.it
I'm working on won200.
I'm tryng to include xml file in my projects.
I use a library (xerces-c_2_8_0 compiled using cygwin) and also other
header file form Xsd. I have write a class wrapper where I can
create-write-delete etc my xml file.
If I add all of those in an older project, anything it's ok: there are no
xml instruction in the main() program and the new files are complete. I
can compile-run-debug project.
If I create a new empty project with all those files included, I can
compile it but it doesn't run! Also the Debug doesn't run and say me "no
Source available for xerces_2_8_0:: etc etc"
So, why everything it's ok for a old project but not for a new
project?!?!?!
The files are the same, also the path.
thanks
Re: Compile but the debug doesn't run [message #259919 is a reply to message #259900] |
Thu, 03 July 2008 10:19  |
Originally posted by: rtroy.sciencetools.com
I'm no expert, but it's worth asking: Have you "configured" it to run?
From the main window, Run -> [Run Configurations... || Debug
Configurations ] -> <type of thing you want to run> ->
and then continue the dialogue with whatever's important to you.
You might look at the [Run || Debug] configuration of the older project.
Good luck,
Richard
FUDForum. Page generated in 0.12025 seconds
