Home » Archived » EPF » plugin and tool mentors
plugin and tool mentors [message #25674] Tue, 19 December 2006 14:28 Go to next message
Originally posted by: claude.aubryconseil.com
I had a process including tool mentors. I made a separated plugin -for
the tool and the tool mentors- which references the base process. I want
to re-associate tool mentors to the tasks. The solution that I found
requires to create in the tool plugin new tasks which extend those of
the basic process and then to associate the tool mentors to them. I have
also to create categories for the publication of these tasks.
Is there a simpler solution?
Claude
Re: plugin and tool mentors [message #26176 is a reply to message #25674] Tue, 09 January 2007 12:58 Go to previous messageGo to next message
Originally posted by: phaumer.xxx.com
Yes, that is the best way to do it. If you want to decouple your tool
mentors from your content you need such an indirection.
Thanks and best regards,
Peter Haumer.
____________________________________________________________ __
PETER HAUMER
IBM | Eclipse Process Framework Committer
"Claude Aubry" <claude@aubryconseil.com> wrote in message
news:em9egf$6fp$1@utils.eclipse.org...
>I had a process including tool mentors. I made a separated plugin -for the
>tool and the tool mentors- which references the base process. I want to
>re-associate tool mentors to the tasks. The solution that I found requires
>to create in the tool plugin new tasks which extend those of the basic
>process and then to associate the tool mentors to them. I have also to
> Claude
Re: plugin and tool mentors [message #26258 is a reply to message #26176] Wed, 10 January 2007 05:13 Go to previous message
It would be much easier if the dependence between tool mentors and tasks
was reversed, allowing making the link from the tool mentor.
Claude
Re: plugin and tool mentors [message #574490 is a reply to message #25674] Tue, 09 January 2007 12:58 Go to previous message
Peter Haumer.
PETER HAUMER
> Claude
Re: plugin and tool mentors [message #574588 is a reply to message #26176] Wed, 10 January 2007 05:13 Go to previous message
Claude
Previous Topic:getting sourcecode via cvsgrab ERROR
Next Topic:Activity Entry & Exit State.
Current Time: Fri May 09 09:09:17 EDT 2025
Powered by FUDForum. Page generated in 0.02558 seconds
