Home » Archived » BIRT » parameters in Javascript problem after upgrate to 2.2.1
parameters in Javascript problem after upgrate to 2.2.1 [message #259711] Sun, 28 October 2007 19:26 Go to next message
Hello!
Can you PLEASE help:
We had a number of BIRT reports which were working fine in old version.
After we upgrated to a new version all of them have the same problem with
parameters- in scripting tab , BeforeOpen i have this script (i need it to
determine if the report is running from TomCat or designer):
/*change end day to sundaY */
startdate =testForStringDate();
mycalcdate = endate(startdate);
function testForStringDate()
if ( params["p_start_string"] == "unknown" ) {
return params["p_start_date"]
} else {
fmt = new java.text.SimpleDateFormat("MMddyy");
return fmt.parse(params["p_start_string"]);
function endate(ps)
if (getDayOfWeek(ps)==6)
var myDate1= DateTimeSpan.addDate( ps,0, 0,2 )
else if (getDayOfWeek(ps)==5)
var myDate1= DateTimeSpan.addDate( ps,0, 0,3 )
else if (getDayOfWeek(ps)==4)
var myDate1= DateTimeSpan.addDate( ps,0, 0,4 )
else if (getDayOfWeek(ps)==3)
var myDate1= DateTimeSpan.addDate( ps,0, 0,5 )
else if (getDayOfWeek(ps)==2)
var myDate1= DateTimeSpan.addDate(ps,0, 0,6 )
else if (getDayOfWeek(ps)==7)
var myDate1= DateTimeSpan.addDate( ps,0, 0,1 )
else
{var myDate1= ps}
fmt = new java.text.SimpleDateFormat("yyyy-MM-dd");
return fmt.format(myDate1);
and i used mycalcdate as a parameter in DataSet. But now if i put
mycalcdate as a parameter in DataSet it dissapears and parameter is
getting empty. May be now i need to put my script in different place? what
happening even before BeforeOpen??
Please help!! If you need more info- please let me know. Thank you
Natasha
Re: parameters in Javascript problem after upgrate to 2.2.1 [message #259713 is a reply to message #259711] Mon, 29 October 2007 01:47 Go to previous messageGo to next message
Actualy found it myself- now if you use Default value in DataSet for
parameter it disappear, but report is still working, you can't use Preview
Results in DataSet. May be it's a known bug...
Re: parameters in Javascript problem after upgrate to 2.2.1 [message #260329 is a reply to message #259713] Fri, 02 November 2007 03:32 Go to previous message
Hi, may i have the report that you fail in 2.2.1? I want to know more if
it has a bug in it. And I can not know very clearly.
Previous Topic:creating custom chart
Next Topic:Chart Grouping
Current Time: Sun Jul 27 12:36:34 EDT 2025
Powered by FUDForum. Page generated in 0.05337 seconds
