Home » Newcomers » Newcomers » Ctrl+H Search keybinding not working in Ganymede
Ctrl+H Search keybinding not working in Ganymede [message #259627] Mon, 30 June 2008 11:02 Go to next message
Originally posted by: wieant.nielander.altium.nl
I recently switched from Europa to Ganymede and somehow cannot get the
Ctrl+H keybinding to the Search dialog working. Pressing Ctrl+H in whatever
context doesn't seem to have any effect. The Preferences | General | Keys
dialog doesn't show any conflict and also changing the keybinding doesn't
seem to have any effect. Is this a known issue?
Re: Ctrl+H Search keybinding not working in Ganymede [message #259650 is a reply to message #259627] Mon, 30 June 2008 17:29 Go to previous messageGo to next message
I don't see this happening in my install. It might be worth adding
"-debug -consolelog" to your command line and see if the console window
indicates any relevant conflicts or errors.
Re: Ctrl+H Search keybinding not working in Ganymede [message #259686 is a reply to message #259650] Tue, 01 July 2008 04:07 Go to previous message
Thanks for trying, just retried it with a 'clean' Ganymede SDK install and then
indeed Ctrl+H just works fine. It seems one specific plugin we installed
on top of the SDK causes the misbehaviour.
Previous Topic:'Computing Source' has encountered a problem
Next Topic:Breadcrumbs only used for Java files?
Current Time: Mon Jul 21 21:54:47 EDT 2025
Powered by FUDForum. Page generated in 0.14894 seconds
