Home » Language IDEs » Java Development Tools (JDT) » Generating a javadoc comment programmatically
Generating a javadoc comment programmatically [message #259523] Fri, 10 April 2009 07:54 Go to next message
Originally posted by: Rudolf.Ziegaus.gmx.de
He
is there a way to generate a javadoc comment programmatically? I'd like to
check if the comment still is correct (regarding number and type of
parameters) and if not I'd like to modify or insert the comment on the fly.
Thx in advance for any hints,
Rudi
Re: Generating a javadoc comment programmatically [message #259544 is a reply to message #259523] Tue, 14 April 2009 03:01 Go to previous messageGo to next message
Rudolf Ziegaus wrote:
> He
Why would you want to do this? There are already quick fixes that do this.
Dani
> Rudi
Re: Generating a javadoc comment programmatically [message #259547 is a reply to message #259544] Tue, 14 April 2009 16:49 Go to previous messageGo to next message
>> He
> Dani
>> Rudi
Blush;-) I got caught in the act;-)
I would like to do this not only for a single method but for a working set
consisting of possibly thousands of classes...
AFAIK the quick fix is only for a single method, isn't it?
Rudi
Re: Generating a javadoc comment programmatically [message #259552 is a reply to message #259547] Wed, 15 April 2009 00:55 Go to previous messageGo to next message
Originally posted by: no.ddress.here
In article <so8ori2xx9fs$.1vnm2fa62oaqf$.dlg@40tude.net>,
Rudolf.Ziegaus@gmx.de says...>
> Rudi
Take a look at JAutoDoc.
Search for it at http://www.eclipseplugincentral.com/
Re: Generating a javadoc comment programmatically [message #259567 is a reply to message #259547] Wed, 15 April 2009 09:30 Go to previous message
>>> He
>> Dani
>>> Rudi
If the compiler settings are set accordingly then the problems are
reported for you i.e. you only need to add code that can fix those
reported problems. You can start to dig into the code of
org.eclipse.jdt.internal.ui.text.correction.JavadocTagsSubPr ocessor.
Dani
> Rudi
Previous Topic:get information about TextEdit
Next Topic:Extending Java Search Functionality From the Result View Toolbar
Current Time: Sat Nov 01 09:17:14 EDT 2025
Powered by FUDForum. Page generated in 0.04151 seconds
