Home » Newcomers » Newcomers » The ordinal 3873 could not be located in the dynamic link library LIBEAY32.dll
The ordinal 3873 could not be located in the dynamic link library LIBEAY32.dll [message #259520] Sun, 29 June 2008 10:45 Go to next message
Originally posted by: kapil.sharma.ymail.com
Hi everyone
Yesterday I downloaded the latest eclipse Ganemede
Eclipse IDE for Java EE Developers (163 MB) and also installed SVN
Connector
org.polarion.eclipse.team.svn.connector.javahl.sources_2.0.1 .I20080612-1500
for the svn. Also I have the plugin of svnkit.com.
But now every time I start eclipse.exe I am getting the following dialog:
LIBEAY32.dll
This error message is very annoying to me. I never got this message before
in the previous versions of eclipse. But this is also true I did not try
those plugins before.I copied the LIBEAY32.dll in my win32 directory but
still the same message is popping up.
If some body can explain or help me why this message is coming right in
the beginning that would be really helpful.
I know its bit tricky but I am sure intelligent people can solve it in the
matter of seconds.
Your response is really appreciated!
Re: The ordinal 3873 could not be located in the dynamic link library LIBEAY32.d [message #259575 is a reply to message #259520] Mon, 30 June 2008 03:38 Go to previous messageGo to next message
Originally posted by: daniel.s128928957.online.de
Hi there,
I have exactly the same problem. I get this message as soon as eclipse is
loaded completely. Although I just run the classic bundle and I got this
message also before I installed subversive.
Eclipse SDK
Version: 3.4.0
Build id: I20080617-2000
Any help appreciated!
Daniel
Re: The ordinal 3873 could not be located in the dynamic link library LIBEAY32.d [message #260749 is a reply to message #259575] Fri, 11 July 2008 07:13 Go to previous messageGo to next message
Originally posted by: nospam.please.com
Changing my startup vm from jdk1.5.0_14 to a newer jdk1.6 version fixed
this for me. Would be good to know the reason for the problem though.
Ashis
Re: The ordinal 3873 could not be located in the dynamic link library LIBEAY32.d [message #262769 is a reply to message #260749] Sat, 09 August 2008 07:30 Go to previous messageGo to next message
Originally posted by: SS.mailinator.com
I have the same problem
Re: The ordinal 3873 could not be located in the LIBEAY32.dll [message #263659 is a reply to message #259520] Tue, 26 August 2008 03:33 Go to previous message
Originally posted by: GSN.noserver.ru
kapil sharma, òû íå îäèíîê :(
Previous Topic:problem in strting Eclipse in LINUX
Next Topic:Writing to Problems View
Current Time: Sat Nov 01 09:14:53 EDT 2025
Powered by FUDForum. Page generated in 0.07128 seconds
