Home » Archived » XML Schema Definition (XSD) » Generating Java Classes from XSD
Generating Java Classes from XSD [message #25645] Thu, 31 July 2003 12:44 Go to next message
Originally posted by: cipher8000.yahoo.com
Hi all,
Is there any libraries to generate java classes from eclipse xsd ( like JAXB
compiler)?
-muruga
Re: Generating Java Classes from XSD [message #25705 is a reply to message #25645] Thu, 31 July 2003 13:03 Go to previous messageGo to next message
Muruga,
See
http://dev.eclipse.org/viewcvs/indextools.cgi/%7Echeckout%7E /emf-home/docs/xlibmod/xlibmod_main.html
Muruga wrote:
> Hi all,
> compiler)?
> -muruga
Re: Generating Java Classes from XSD [message #25729 is a reply to message #25705] Thu, 31 July 2003 13:16 Go to previous messageGo to next message
Hi Ed,
Thanks for the quick response and thanks very much for the link. The
tutorial shows how to generate in Eclipse. But i want to generate from a
stand-alone application. It would be very helpful if there is any guide for
using these EMF libraries in stand-alone mode to generate java classes.
-Muruga
"Ed Merks" <merks@ca.ibm.com> wrote in message
news:3F294BD6.713A47B0@ca.ibm.com...
Muruga,
See
Muruga wrote:
> Hi all,
JAXB
> compiler)?
> -muruga
Re: Generating Java Classes from XSD [message #25859 is a reply to message #25729] Thu, 31 July 2003 13:20 Go to previous message
Muruga,
The EMF generator doesn't run standalone but it can be made to run headless from
the command line. Unfortunately, we haven't written the scaffolding to support
XSD to Ecore conversion from the command line. External contributions would be
most welcome. ;-)
Muruga wrote:
> Hi Ed,
> -Muruga
> Muruga,
> See
> Muruga wrote:
> > Hi all,
> JAXB
> > compiler)?
> > -muruga
Re: Generating Java Classes from XSD [message #575164 is a reply to message #25645] Thu, 31 July 2003 13:03 Go to previous message
Muruga,
See
Muruga wrote:
> Hi all,
> compiler)?
> -muruga
Re: Generating Java Classes from XSD [message #575231 is a reply to message #25705] Thu, 31 July 2003 13:16 Go to previous message
Hi Ed,
-Muruga
Muruga,
See
Muruga wrote:
> Hi all,
JAXB
> compiler)?
> -muruga
Re: Generating Java Classes from XSD [message #575361 is a reply to message #25729] Thu, 31 July 2003 13:20 Go to previous message
Muruga,
most welcome. ;-)
Muruga wrote:
> Hi Ed,
> -Muruga
> Muruga,
> See
> Muruga wrote:
> > Hi all,
> JAXB
> > compiler)?
> > -muruga
Previous Topic:namespace prefix to URL resolution
Next Topic:namespace prefix to URL resolution
Current Time: Thu Jul 24 10:37:30 EDT 2025
Powered by FUDForum. Page generated in 0.04102 seconds
