Home » Newcomers » Newcomers » Eclipse question re auto insert of import statement
Eclipse question re auto insert of import statement [message #259418] Fri, 27 June 2008 11:57 Go to next message
I recall reading somewhere that Eclipse has a feature where you can use
a class in your code and if it is not defined yet, you can hit something
(ctrl-1 ?) and have it automatically know what package to import.
This feature is not working for my packages nor the BlackBerry
packages. Any ideas how to make this work?
Paul
Re: Eclipse question re auto insert of import statement [message #259422 is a reply to message #259418] Fri, 27 June 2008 12:13 Go to previous messageGo to next message
I got this one solved -
If you put the cursor on an undefined class and hit ctrl-shift-m
(Windows) then Eclipse should pull in the required import, as long as it
can find it.
My thanks to richard.puckett
> Paul
Re: Eclipse question re auto insert of import statement [message #259431 is a reply to message #259422] Fri, 27 June 2008 13:55 Go to previous messageGo to next message
> can find it.
Note that Ctrl+Shift+o (Organize Imports) will also insert missing
import statements (it will prompt you if there is ambiguity about which
class to import based on the project's build path).
Also, Ctrl+Space will offer suggestions for fully-qualified class names
and automatically add import statements when you select the exact one
you want. Ctrl+Space is a very powerful tool in general - it does a lot
more than that.
Hope this helps,
Eric
>> use a class in your code and if it is not defined yet, you can hit
>> something (ctrl-1 ?) and have it automatically know what package to
>> import.
>> Thanks,
>> Paul
Re: Eclipse question re auto insert of import statement [message #259435 is a reply to message #259431] Fri, 27 June 2008 14:04 Go to previous messageGo to next message
Thanks Eric. I had tried Ctrl+Space and it was not offering any
suggestions for imports. But Ctrl+shift+m worked perfectly.
I'll certainly play with the other suggestions you gave.
Paul
>> it can find it.
> more than that.
> Hope this helps,
> Eric
>>> import.
>>> Thanks,
>>> Paul
Re: Eclipse question re auto insert of import statement [message #259723 is a reply to message #259435] Tue, 01 July 2008 07:04 Go to previous message
Right. It should only suggest the types. If you then select the type it
will add the import automatically.
Dani
> Paul
>>> as it can find it.
>> which class to import based on the project's build path).
>> names and automatically add import statements when you select the
>> exact one you want. Ctrl+Space is a very powerful tool in general -
>> it does a lot more than that.
>> Hope this helps,
>> Eric
>>>> import.
>>>> Thanks,
>>>> Paul
Previous Topic:Breadcrumbs only used for Java files?
Next Topic:File Explorer does not work on a Network
Current Time: Thu Nov 06 00:59:46 EST 2025
Powered by FUDForum. Page generated in 0.10978 seconds
