Re: Eclipse 3.4 help system not working correctly on Ubuntu 7.10 [message #259254 is a reply to message #259240] |
Thu, 26 June 2008 10:02 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: mknauer.innoopract.com
Petter Holmström wrote:
> I downloaded Eclipse 3.4 yesterday and installed into by laptop running
> Ubuntu 7.10 (32-bit). Overall it seems to be working just fine, however
> the help system is not working properly.
Can you send us some more details? The exact Java version that you are
running, etc.
Did you try to use an external browser for the embedded Eclipse help? There
is an option in the preferences.
And if everything fails: http://help.eclipse.org/ganymede
Markus
Re: Eclipse 3.4 help system not working correctly on Ubuntu 7.10 [message #259299 is a reply to message #259240] |
Thu, 26 June 2008 12:28 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: nospam_kowalskilee.gmail.com
Hi Petter,
That image looks like the Help UI running in Basic UI mode. It is the
Advanced UI mode that gives the richer UI abilities (expand/collapse, etc).
The help system will show in Basic UI if the available browser is not an
advanced browser such as Firefox/Mozilla (or IE on Windows).
On Linux, Eclipse should be using the Mozilla widget. Somehow, it
doesn't look like that is working on your system.
You can try specifying "use external browser" in the Preferences - Help,
as another poster suggested. With that setting, Eclipse will try to find
your defined system browser and use it, and if it is Firefox/Mozilla,
then you'll get the advanced UI.
I'm adding eclipse.platform.ua newsgroup to this thread, as that
newsgroup covers the help system.
Lee Anne
> Hello everyone,
> The only view that works as it should is the actual help text view. The
> TOC show up in large, unformatted text without the ability to collapse
> or expand individual topics (they are all expanded by default). The tabs
> at the bottom are completely missing. The back and forward navigation
> buttons are also missing, as is the quick search field at the top-left
> corner.
> On Windows, the help system works just fine. Any ideas what could have
> caused this problem?
> Thanks in advance,
> -Petter-
Bugzilla has been opened for this (was Re: Eclipse 3.4 help system not working correctly on Ubuntu 7 [message #259340 is a reply to message #259240] |
Thu, 26 June 2008 18:03 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Hi Petter,
I just saw that a Bugzilla bug has been opened for this symptom running
on Ubuntu 8.04.
You might want to cc yourself on this bug entry:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=238533
I think it is the same symptom/problem.
Lee Anne
> Hello everyone,
> corner.
> Thanks in advance,
> -Petter-
Re: Bugzilla has been opened for this (was Re: Eclipse 3.4 help system not working correctly on Ubun [message #259344 is a reply to message #259340] |
Thu, 26 June 2008 18:40 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Petter Holmstroem![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=petter.holmstrom%40abo.fi) Messages: 4 Registered: July 2009 |
Junior Member |
Thanks, I also added my system details to the bug report (as requested
in an earlier reply in this thread).
-Petter-
Lee Anne wrote:
> Hi Petter,
> on Ubuntu 8.04.
> Best regards,
> Lee Anne
>> Hello everyone,
>> corner.
>> Thanks in advance,
>> -Petter-
Re: Bugzilla has been opened for this (was Re: Eclipse 3.4 help system not working correctly on Ubun [message #259812 is a reply to message #259344] |
Wed, 02 July 2008 17:04 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Chris Goldthorpe![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=cgold%40us.ibm.com) Messages: 815 Registered: July 2009 |
It is the same bug and I am investigating it right now.
> Hello,
> -Petter-
> Lee Anne wrote:
>> Hi Petter,
>> on Ubuntu 8.04.
>> Best regards,
>> Lee Anne
>>> Hello everyone,
>>> corner.
>>> Thanks in advance,
>>> -Petter-
FUDForum. Page generated in 0.08422 seconds
