Home » Eclipse Projects » Eclipse Platform » [JFace] multiple partitionings
[JFace] multiple partitionings [message #259228] Wed, 07 July 2004 11:10 Go to next message
Originally posted by: daniel.rohe.stud.tu-ilmenau.de
Hello newsgroup,
I have a document with multiple partitionings, maybe PHP and HTML or JSP and
HTML. Is it possible to create a single source editor that contains a
document with multiple partitionings and also multiple source viewers for
displaying the document partitions in the single source editor? Or is the
only possible solution to use a partition scanner for partitioning and a
scanner for each partition?
Greetings,
Daniel
Re: [JFace] multiple partitionings [message #259616 is a reply to message #259228] Thu, 08 July 2004 09:28 Go to previous message
Not quite sure what you mean by an editor with multiple viewers - a
multi-page editor with mutiple tabs?
> Or is the
I suggest the latter - Note that a document supports multiple
paritionings in parallel (see IDocumentExtension3). And each
partitioning can dissect the document into a different set of partitions.
-tom
Previous Topic:Missing Project Type on Eclipse 3.0 on Mac OSX
Next Topic:Eclipse 3.0 Ant editor problem
Current Time: Sun Jul 13 09:48:14 EDT 2025
Powered by FUDForum. Page generated in 0.03809 seconds
