Home » Language IDEs » ServerTools (WTP) » feature request
feature request [message #25568] |
Mon, 07 June 2004 10:49  |
I wanted to propose a feature for the web tools.
I often saw jsp pages outside the web root folder (if you have pages that
differ in function of the deployement environment -dev,test,prod...-).
in every tools i saw (lomboz, myeclipseide, ...), i don't see the
possibility to edit them properly (code assist, taglibs...) without errors.
it should be good for jsp pages not to be dependant of a structure for jsp
(like for java file). Adding taglibs as a property of project (like jars
for java compiling) would be a very interessting feature.
thank you,
___
Nicolas YOUNA
Re: feature request [message #25608 is a reply to message #25568] |
Tue, 08 June 2004 07:29   |
Originally posted by: gercan.REMOVE_ME.acm.org
Hi Nicolas,
Actually Lomboz provides a feature similiar to what you described. In
lomboz it is possible to define a web module to be the default web module
for the project. When this is done any jsp files that is not part of the
web module directory structure are treated as if they are a part of the
default web module
Gorkem Ercan
Nicolas YOUNA wrote:
> Hello,
> thank you,
> ___
> Nicolas YOUNA
Re: feature request [message #25757 is a reply to message #25608] |
Tue, 08 June 2004 09:13   |
you are right,
but we are always dependant of a deployed webapp structure (ie: a webRoot
with inside a WEB-INF folder, lib are in WEB-INF/lib...)
actually i have a projet structure like that:
/myProjet
---/src : java sources
---/env : environment specific folder
------/env1 : contains env1 environment files
------/env2 : contains env2 environment files
---/etc : other files (.properties .xml ...)
---/web : web root (without a WEB-INF folder)
---/lib : lib required for the project
i have a ANT script that deploy the project for me ->
compile java sources
zip classes and .properties (depending of the environment target) into a
jar
copy web folder content into the deployment directory
create WEB-INF directory
copy lib jars and project jar into WEB-INF/lib
copy environment specific files into their right place (including
"web.xml")
actualy, i need to set the webRoot folder to "web", create an artificial
WEB-INF directory in it (contening copies of jars, *.properties ...)
i know that i can change the default Java-Builder for a project (or add
ant scripts to it) so i can automatically redeloyed it on my tomcat. But i
still can't remove this anoying WEB-INF directory on my web directory to
continue to developpe correctly.
do you see more precisely my needs?
___
Nicolas YOUNA
Gorkem Ercan wrote:
> Hi Nicolas,
> default web module
> Gorkem Ercan
> > Hello,
> > thank you,
> > ___
> > Nicolas YOUNA
Re: feature request [message #25767 is a reply to message #25757] |
Wed, 09 June 2004 10:29   |
this was a feature I asked before in lomboz, to allow to set a different
directory for run-time lib, xml's and properties files, and jsp's and
html's. But you can use a directory with the default structure of a war file
too.
Emerson
"Nicolas YOUNA" <nyouna@online.fr> escreveu na mensagem
news:ca4e1f$4cp$1@eclipse.org...
> you are right,
> /myProjet
> jar
> "web.xml")
> ___
> Nicolas YOUNA
> Gorkem Ercan wrote:
> > Hi Nicolas,
module
> > default web module
> > Gorkem Ercan
> > > Hello,
that
errors.
jsp
jars
> > > thank you,
> > > ___
> > > Nicolas YOUNA
Outgoing mail is certified Virus Free.
Checked by AVG anti-virus system (http://www.grisoft.com).
Version: 6.0.701 / Virus Database: 458 - Release Date: 7/6/2004
Re: feature request [message #25783 is a reply to message #25767] |
Thu, 10 June 2004 04:52  |
> too.
yes i can, this is what i use to do. But i must change the ant script to
match to this and i can't : the other guys of my team works on NetBeans,
the ant script is shared between us. So i have my ant script which is not
commited in our CVS repository... :'-( . Not too useful...
Nicolas
> too.
> Emerson
> > Hi,
> > you are right,
> > /myProjet
> > jar
> > "web.xml")
> > ___
> > Nicolas YOUNA
> > Gorkem Ercan wrote:
> > > Hi Nicolas,
> module
> > > default web module
> > > Gorkem Ercan
> > > > Hello,
> that
> errors.
> jsp
> jars
> > > > thank you,
> > > > ___
> > > > Nicolas YOUNA
Current Time: Fri May 09 12:43:21 EDT 2025
Powered by FUDForum. Page generated in 0.04241 seconds
