Home » Eclipse Projects » Eclipse Platform » Bug? Completion goes to next line
Bug? Completion goes to next line [message #258462] Mon, 05 July 2004 10:51 Go to next message
I'm using 3.0 Final on Linux. I noticed new behaviour: when I type and use
code completion (Ctrl-Space), the cursor will be positioned on the next
line, instead of at the end of the currently completed code. Has anyone
else seen this?
L
Re: Bug? Completion goes to next line [message #258653 is a reply to message #258462] Tue, 06 July 2004 05:34 Go to previous messageGo to next message
I have seen it, but could never reproduce - please file a bug against
platform-text if you have steps to reproduce.
-tom
Laurent Duperval wrote:
> else seen this?
> L
Re: Bug? Completion goes to next line [message #258658 is a reply to message #258653] Tue, 06 July 2004 05:38 Go to previous messageGo to next message
I friend had this problem too. Restarting Eclipse seems to fix it.
/Jesper Nordenberg
> -tom
>> use
>> else seen this?
>> L
Re: Bug? Completion goes to next line [message #258708 is a reply to message #258462] Tue, 06 July 2004 08:18 Go to previous message
I saw behavior that sounds similar to this under m8 (so did a co-worker),
but I have not seen it since. I filed a bug:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=62173
For me, reopening the particular editor exhibiting the behavior seemed to
fix the problem; i.e. it was not global across all editors.
-Ernest
"Laurent Duperval" <lduperval@yahoo.com> wrote in message
news:pan.2004.07.05.14.51.03.324072@yahoo.com...
> else seen this?
> L
Previous Topic:Change comment of CVS files
Next Topic:Running more than one set of JUnit tests?
Current Time: Tue Jul 22 13:03:58 EDT 2025
Powered by FUDForum. Page generated in 0.04149 seconds
