Re: [buckminster-dev] PDE headless build of RCP headless product ... "The System Bundle's start [message #25539] |
Fri, 19 September 2008 12:35 |
Originally posted by: ki.alam.gmail.com
------=_Part_45660_2038562.1221842155730
Content-Type: text/plain; charset=ISO-8859-1
Content-Disposition: inline
Thanks, Thomas,
We did not use a custom config.ini, but looking into it, it turned out that
the config.ini from our original PDE-headless-build system generated
correctly using the configurator bundle, but the buckminster generated
config.ini just wouldn't work.
Is there some reason that the PDE build and buckminster don't generate
identical config.ini files?
This is buckminster for 3.4.
Again, many thanks.
Ki
Date: Fri, 19 Sep 2008 07:53:33 +0200
Subject: Re: [buckminster-dev] PDE headless build of RCP headless
product ... "The System Bundle's start level can not be
modified."
To: Buckminster developer discussions <buckminster-dev@eclipse.org>
Message-ID: <48D33E5D.8050206@tada.se>
Hi Ki,
Do you have a custom config.ini file for you RCP app?
Are you using Buckminster for 3.3 or 3.4?
Thomas Hallgren
Ki Alam wrote:
> Hi there.
> We are trying to transition our build from the PDE headless build to
> the buckminster headless build. We got through the resolve bits and
> are able to build , but when trying to run the build, we get the
> following error:
> !SESSION 2008-09-18 05:18:19.011
> eclipse.buildId=unknown
> java.version=1.6.0_03
> java.vendor=Sun Microsystems Inc.
> BootLoader constants: OS=linux, ARCH=x86, WS=gtk, NL=en_US
> !ENTRY org.eclipse.osgi 4 0 2008-09-18 05:18:19.654
> !MESSAGE An unexpected runtime error has occurred.
> !STACK 0
> java.lang.IllegalArgumentException: The System Bundle's start level
> can not be modified.
> at
org.eclipse.osgi.framework.internal.core.StartLevelManager.s etBundleStartLevel(StartLevelManager.java:415)
> at
org.eclipse.core.runtime.adaptor.EclipseStarter.installBundl es(EclipseStarter.java:1117)
> at
org.eclipse.core.runtime.adaptor.EclipseStarter.loadBasicBun dles(EclipseStarter.java:642)
> at
org.eclipse.core.runtime.adaptor.EclipseStarter.access$1(Ecl ipseStarter.java:619)
> at
org.eclipse.core.runtime.adaptor.EclipseStarter$1.bundleChan ged(EclipseStarter.java:308)
> at
org.eclipse.osgi.framework.internal.core.BundleContextImpl.d ispatchEvent(BundleContextImpl.java:1234)
> at
org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEve nt(EventManager.java:211)
> at
org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEv entSynchronous(ListenerQueue.java:141)
> at
org.eclipse.osgi.framework.internal.core.Framework.publishBu ndleEventPrivileged(Framework.java:1518)
> at
org.eclipse.osgi.framework.internal.core.Framework.publishBu ndleEvent(Framework.java:1469)
> at
org.eclipse.osgi.framework.internal.core.StartLevelManager.d oSetStartLevel(StartLevelManager.java:281)
> at
org.eclipse.osgi.framework.internal.core.StartLevelManager.l aunch(StartLevelManager.java:247)
> at
org.eclipse.osgi.framework.internal.core.SystemBundle.resume (SystemBundle.java:201)
> at
org.eclipse.osgi.framework.internal.core.Framework.launch(Fr amework.java:644)
> at
> org.eclipse.osgi.framework.internal.core.OSGi.launch(OSGi.ja va:51)
> at
org.eclipse.core.runtime.adaptor.EclipseStarter.startup(Ecli pseStarter.java:313)
> at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:175)
> at
> at
> at java.lang.reflect.Method.invoke(Method.java:597) at
> org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 549)
> at
> org.eclipse.equinox.launcher.Main.basicRun(Main.java:504) at
> org.eclipse.equinox.launcher.Main.run(Main.java:1236)
> at org.eclipse.equinox.launcher.Main.main(Main.java:1212)
> !ENTRY org.eclipse.osgi 4 0 2008-09-18 05:18:19.655
> !MESSAGE
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> !ENTRY org.eclipse.osgi 4 0 2008-09-18 05:18:19.656
> !MESSAGE Application error
> !STACK 1
> java.lang.IllegalStateException: Platform not running
> at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:370)
> at
> Followed by the bundles not being able to be resolved:
> !ENTRY org.eclipse.osgi 2 0 2008-09-18 05:18:19.677
> !MESSAGE One or more bundles are not resolved because the following
> root constraints are not resolved:
> !SUBENTRY 1 org.eclipse.osgi 2 0 2008-09-18 05:18:19.677
> !MESSAGE Bundle
> initial@reference:file:plugins/m365.agent.logmessageservice_1.0.0.jar/
> was not resolved.
> !SUBENTRY 2 m365.agent.logmessageservice 2 0 2008-09-18 05:18:19.678
> !MESSAGE Missing required bundle wily.introscope.em_0.0.0.
> !SUBENTRY 1 org.eclipse.osgi 2 0 2008-09-18 05:18:19.678
> !MESSAGE Bundle
> initial@reference
:file:plugins/m365.embeddedem.datacenter.properties_1.0.0.ja r/
> was not resolved.
> !SUBENTRY 2 m365.embeddedem.datacenter.properties 2 0 2008-09-18
> 05:18:19.678
> !MESSAGE Missing host wily.introscope.em_1.0.0.
> !MESSAGE Bundle
> initial@reference:file:plugins/m365.messaging.transport.sender_1.0.0.jar/
> was not resolved.
> !SUBENTRY 2 m365.messaging.transport.sender 2 0 2008-09-18 05:18:19.678
> !MESSAGE Missing imported package m365_0.0.0.
> !MESSAGE Bundle
> initial@reference
:file:plugins/m365.agent.classanalysis.isengard_1.0.0.jar/
> was not resolved.
> !SUBENTRY 2 m365.agent.classanalysis.isengard 2 0 2008-09-18 05:18:19.678
> !MESSAGE Bundle
> initial@reference:file:plugins/m365.isengard_1.0.0.jar/ was not resolved.
> !SUBENTRY 2 m365.isengard 2 0 2008-09-18 05:18:19.678
> We are able to build using the existing PDE-headless build ... has
> anyone run into this?
> Ki
> _______________________________________________
> buckminster-dev mailing list
> https://dev.eclipse.org/mailman/listinfo/buckminster-dev
<div dir="ltr">Thanks, Thomas, <br><br>We did not use a custom config.ini, but looking into it, it turned out that the config.ini from our original PDE-headless-build system generated correctly using the configurator bundle, but the buckminster generated config.ini just wouldn't work.<br>
<br>Is there some reason that the PDE build and buckminster don't generate identical config.ini files?<br><br>This is buckminster for 3.4.<br><br>Again, many thanks.<br><br>Ki<br><br><br><br>Date: Fri, 19 Sep 2008 07:53:33 +0200<br>
From: Thomas Hallgren <<a href="mailto:thomas@tada.se">thomas@tada.se</a>><br>
Subject: Re: [buckminster-dev] PDE headless build of RCP headless<br>
product ... "The System Bundle's start level can not be modified."<br>
To: Buckminster developer discussions <<a href="mailto:buckminster-dev@eclipse.org">buckminster-dev@eclipse.org</a>><br>
Message-ID: <<a href="mailto:48D33E5D.8050206@tada.se">48D33E5D.8050206@tada.se</a>><br>
Content-Type: text/plain; charset=ISO-8859-1; format=flowed<br>
<br>
Hi Ki,<br>
Do you have a custom config.ini file for you RCP app?<br>
Are you using Buckminster for 3.3 or 3.4?<br>
<br>
Regards,<br>
Thomas Hallgren<br>
<br>
Ki Alam wrote:<br>
> Hi there.<br>
><br>
> We are trying to transition our build from the PDE headless build to<br>
> the buckminster headless build. We got through the resolve bits and<br>
> are able to build , but when trying to run the build, we get the<br>
> following error:<br>
><br>
> !SESSION 2008-09-18 05:18:19.011<br>
> ------------------------------<div id=":zt" class="ArwC7c ckChnd">-----------------<br>
> eclipse.buildId=unknown<br>
> java.version=1.6.0_03<br>
> java.vendor=Sun Microsystems Inc.<br>
> BootLoader constants: OS=linux, ARCH=x86, WS=gtk, NL=en_US<br>
><br>
> !ENTRY org.eclipse.osgi 4 0 2008-09-18 05:18:19.654<br>
> !MESSAGE An unexpected runtime error has occurred.<br>
> !STACK 0<br>
> java.lang.IllegalArgumentException: The System Bundle's start level<br>
> can not be modified.<br>
> at<br>
> org.eclipse.osgi.framework.internal.core.StartLevelManager.s etBundleStartLevel(StartLevelManager.java:415) <br>
> at<br>
> org.eclipse.core.runtime.adaptor.EclipseStarter.installBundl es(EclipseStarter.java:1117) <br>
> at<br>
> org.eclipse.core.runtime.adaptor.EclipseStarter.loadBasicBun dles(EclipseStarter.java:642) <br>
> at<br>
> org.eclipse.core.runtime.adaptor.EclipseStarter.access$1(Ecl ipseStarter.java:619) <br>
> at<br>
> org.eclipse.core.runtime.adaptor.EclipseStarter$1.bundleChan ged(EclipseStarter.java:308) <br>
> at<br>
> org.eclipse.osgi.framework.internal.core.BundleContextImpl.d ispatchEvent(BundleContextImpl.java:1234) <br>
> at<br>
> org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEve nt(EventManager.java:211) <br>
> at<br>
> org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEv entSynchronous(ListenerQueue.java:141) <br>
> at<br>
> org.eclipse.osgi.framework.internal.core.Framework.publishBu ndleEventPrivileged(Framework.java:1518) <br>
> at<br>
> org.eclipse.osgi.framework.internal.core.Framework.publishBu ndleEvent(Framework.java:1469) <br>
> at<br>
> org.eclipse.osgi.framework.internal.core.StartLevelManager.d oSetStartLevel(StartLevelManager.java:281) <br>
> at<br>
> org.eclipse.osgi.framework.internal.core.StartLevelManager.l aunch(StartLevelManager.java:247) <br>
> at<br>
> org.eclipse.osgi.framework.internal.core.SystemBundle.resume (SystemBundle.java:201) <br>
> at<br>
> org.eclipse.osgi.framework.internal.core.Framework.launch(Fr amework.java:644) <br>
> at<br>
> org.eclipse.osgi.framework.internal.core.OSGi.launch(OSGi.ja va:51) <br>
> at<br>
> org.eclipse.core.runtime.adaptor.EclipseStarter.startup(Ecli pseStarter.java:313) <br>
> at<br>
> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:175) <br>
> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)<br>
> at<br>
> sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39) <br>
> at<br>
> sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:25) <br>
> at java.lang.reflect.Method.invoke(Method.java:597) at<br>
> org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 549) <br>
> at<br>
> org.eclipse.equinox.launcher.Main.basicRun(Main.java:504) at<br>
> org.eclipse.equinox.launcher.Main.run(Main.java:1236)<br>
> at org.eclipse.equinox.launcher.Main.main(Main.java:1212)<br>
><br>
> !ENTRY org.eclipse.osgi 4 0 2008-09-18 05:18:19.655<br>
> !MESSAGE<br>
> !STACK 0<br>
> at<br>
> at<br>
> at<br>
> at<br>
> at<br>
> at<br>
> at<br>
> at<br>
> at<br>
> at<br>
> at<br>
> at<br>
> at<br>
> at<br>
> at<br>
> at<br>
> at<br>
> at<br>
> at<br>
> at<br>
><br>
> !ENTRY org.eclipse.osgi 4 0 2008-09-18 05:18:19.656<br>
> !MESSAGE Application error<br>
> !STACK 1<br>
> java.lang.IllegalStateException: Platform not running<br>
> at<br>
> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:370) <br>
> at<br>
> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179) <br>
><br>
> Followed by the bundles not being able to be resolved:<br>
><br>
><br>
> !ENTRY org.eclipse.osgi 2 0 2008-09-18 05:18:19.677<br>
> !MESSAGE One or more bundles are not resolved because the following<br>
> root constraints are not resolved:<br>
> !SUBENTRY 1 org.eclipse.osgi 2 0 2008-09-18 05:18:19.677<br>
> !MESSAGE Bundle<br>
> initial@reference:file:plugins/m365.agent.logmessageservice_1.0.0.jar/<br>
> was not resolved.<br>
> !SUBENTRY 2 m365.agent.logmessageservice 2 0 2008-09-18 05:18:19.678<br>
> !MESSAGE Missing required bundle wily.introscope.em_0.0.0.<br>
> !SUBENTRY 1 org.eclipse.osgi 2 0 2008-09-18 05:18:19.678<br>
> !MESSAGE Bundle<br>
> initial@reference :file:plugins/m365.embeddedem.datacenter.properties_1.0.0.ja r/ <br>
> !SUBENTRY 2 m365.embeddedem.datacenter.properties 2 0 2008-09-18<br>
> 05:18:19.678<br>
> !MESSAGE Missing host wily.introscope.em_1.0.0.<br>
> !MESSAGE Bundle<br>
> initial@reference:file:plugins/m365.messaging.transport.sender_1.0.0.jar/<br >
> !SUBENTRY 2 m365.messaging.transport.sender 2 0 2008-09-18 05:18:19.678<br>
> !MESSAGE Missing imported package m365_0.0.0.<br>
> !MESSAGE Bundle<br>
> initial@reference:file:plugins/m365.agent.classanalysis.isengard_1.0.0.jar/<br >
> !SUBENTRY 2 m365.agent.classanalysis.isengard 2 0 2008-09-18 05:18:19.678<br>
> !MESSAGE Bundle<br>
> initial@reference:file:plugins/m365.isengard_1.0.0.jar/ was not resolved.<br>
> !SUBENTRY 2 m365.isengard 2 0 2008-09-18 05:18:19.678<br>
><br>
> We are able to build using the existing PDE-headless build ... has<br>
> anyone run into this?<br>
><br>
> Thanks,<br>
> Ki<br>
><br>
><br>
><br>
><br>
> ------------------------------------------------------------ ------------ <br>
><br>
> _______________________________________________<br>
> buckminster-dev mailing list<br>
> <a href="mailto:buckminster-dev@eclipse.org">buckminster-dev@eclipse.org</a><br>
> <a href="https://dev.eclipse.org/mailman/listinfo/buckminster-dev" target="_blank">https://dev.eclipse.org/mailman/listinfo/buckminster-dev</a><br>
><br>
</div></div>
------=_Part_45660_2038562.1221842155730--
FUDForum. Page generated in 0.02665 seconds
