Home » Archived » IMP » How to get LPG to treat comments as terminals
How to get LPG to treat comments as terminals [message #25538] |
Wed, 19 November 2008 15:02  |
Originally posted by: aker1121.yahoo.com
By looking into how JDT handles JavaDoc I have
started to understand that the parser must produce
terminals for comments. In the DSL we have created
an IDE for comments can occur 'everyware' (like it is
in java, c,c++ etc), so the way forward can not be
to add comments token in the lexical rule file.
Can someone please give me an hint here?
I can see a solution where occurences of whitespace also
could mean a comment, but how do I do that?
I'm fairly new to LPG and DSL so please have oversight
in my lack of understanding for this.
regards,
Aker Br
Re: How to get LPG to treat comments as terminals [message #25730 is a reply to message #25654] |
Thu, 20 November 2008 11:54   |
Trying to clarify myself:
We have implemented the LPG rules (lexer.gi) so that all the comments are
skipped (using skipToken).
So naturally the comments will not end up as a production in the AST. But I
would like to be able to
use comments the same way that JDT uses JavaDoc for method declaration. So
when I hover over a
method invocation I would like to see the comments that was defined prior to
the method declaration part.
I started to use the ASTView provided by the JDT team
(http://www.eclipse.org/jdt/ui/astview/index.php)
and I noticed that the AST for my file contains also all the comments.
So to make it short; I would like to be able to get a production in the AST
for the comments that (might) exist prior to
the method declaration in our DSL. Or if that is easier all the comments in
the file as productions in the AST.
Aker
"Stanley Sutton" <suttons@us.ibm.com> skrev i meddelandet
news:gg221k$a4q$1@build.eclipse.org...
> Hello Acker,
> I am not sure that I understand what you are trying to do.
> I could try to guess, but I think I would be wrong.
> Can you please clarify what you already have and what you are trying to
> achieve?
> Stan
>> regards,
>> Aker Br
Re: How to get LPG to treat comments as terminals [message #25765 is a reply to message #25730] |
Fri, 21 November 2008 15:47   |
Hi Aker,
That's clearer. I am not an expert on the workings of LPG, but I can
tell you a few things that might help.
The LPG representation of the parse stream contains both tokens and
adjuncts, where adjuncts represent comments. Typically, as a file is
parsed by an LPG parser, tokens go into a tokens array, comments go into
an adjuncts array, and a mapping is maintained between them. The
interface lpg.runtime.IParseStream contains methods
IToken[] getFollowingAdjuncts(int i);
IToken[] getPrecedingAdjuncts(int i);
where the argument is the index of a token in the token stream.
Of course, in order to get the comments into the adjuncts array in the
parse stream, you have to specify the grammar or lexer rules
appropriately. In our typical examples, we have rules for single line
comments; this is from a generated Lexer.gi file:
%Rules
Token ::= identifier /. checkForKeyWord();./
| number /. makeToken($_NUMBER);./
| DoubleLiteral /. makeToken($_DoubleLiteral);./
| white /. skipToken();./
| slc /. makeComment($_SINGLE_LINE_COMMENT);./
| ';' /. makeToken($_SEMICOLON);./
Here we do not skipToken for the comment but instead use
makeComment(..). makeComment(..) is the method that adds the comment
token to the adjuncts array.
If you are recognizing comments in your grammar rules (.g file) then I
think you should be able to invoke makeComment(..) from there as well.
Does this seem like it can support what you want to do?
Stan
Aker wrote:
> when I hover over a
> Aker
>> Hello Acker,
>> achieve?
>> Thanks,
>> Stan
>>> regards,
>>> Aker Brückler
Re: How to get LPG to treat comments as terminals [message #25776 is a reply to message #25765] |
Sat, 22 November 2008 05:15   |
Hi Stan,
Not only does it support what I wanted, but it is exactly what I wanted!
Thanks for valuable help. Much appreciated!!
I missed that makeComment ('macro') exists in a sample definition file, but
is there some LPG document (or web page) that covers this (and other
macros)?
BR
Aker
news:gg76p7$g5k$1@build.eclipse.org...
> Hi Aker,
> That's clearer. I am not an expert on the workings of LPG, but I can tell
> %Rules
> | slc /. makeComment($_SINGLE_LINE_COMMENT);./ |
> Here we do not skipToken for the comment but instead use makeComment(..).
> makeComment(..) is the method that adds the comment token to the adjuncts
> array.
> Stan
> Aker wrote:
>> So when I hover over a
>> to the method declaration part.
>> AST for the comments that (might) exist prior to
>> in the file as productions in the AST.
>> Regards,
>> Aker
>>> Hello Acker,
>>> achieve?
>>> Thanks,
>>> Stan
>>>> regards,
>>>> Aker Br
Re: How to get LPG to treat comments as terminals [message #25802 is a reply to message #25776] |
Mon, 24 November 2008 14:49   |
Hi Aker,
Unfortunately, the macros were developed for the templates after the LPG
documentation was written.
It isn't hard to write your own macros, though. At the end of the
lexer.gi file you can introduce a "headers" section, e.g.,
%Headers
private void sayHello() {
System.out.println("Hello world!");
%end
(There is a larger and more useful example at the end of the parser.g
file.) In the "headers" section you can write code for any "macros"
(classes, methods, fields) that you want to use with your rules. Then
you can refer to these in the code that is associated with the rules:
%Rules
sayHello();
Also feel free to use any of the macros that are used in the examples in
any of the templates.
Stan
Aker wrote:
> Hi Stan,
> macros)?
> BR
> Aker
>> Hi Aker,
>> %Rules
>> array.
>> Regards,
>> Stan
>> Aker wrote:
>>> Hi,
>>> Regards,
>>> Aker
>>>> Hello Acker,
>>>> achieve?
>>>> Thanks,
>>>> Stan
>>>>> regards,
>>>>> Aker Brückler
Re: How to get LPG to treat comments as terminals [message #26892 is a reply to message #25841] |
Mon, 02 March 2009 01:57  |
Ed Willink wrote:
> Instead it may be better to use an enhanced Token to which a
> partial-line single-line-comment is attached as a suffix and to which
> other paragraph and full-line single-line-comments are attached as
> prefixes. The Tokens then parse normally but persist the comments for
> those activities that require them.
Actually there's no need to do anything. Leave comments out of the grammar,
they can always be recovered later by a special purpose comment, newline,
whitespace analyzer.
The comments for 'currentToken' are those between 'previousToken'.end
and 'currentToken'.start and/or between 'currentToken'.end
and 'nextToken'.start. Working in this way will allow you to use
syntactic context to decide how much of A,B,C,D,E in
int a; // A
// B
/* C */
* D
// E
int e;
belongs to int a, and how much to int e; It also gives
you more scope for inserting tabs for refactoring and other issues.
Ed Willink
Re: How to get LPG to treat comments as terminals [message #574325 is a reply to message #25538] |
Wed, 19 November 2008 16:56  |
Hello Acker,
achieve?
Stan
> regards,
> Aker Brückler
Re: How to get LPG to treat comments as terminals [message #574407 is a reply to message #25654] |
when I hover over a
Aker
> Hello Acker,
> achieve?
> Stan
>> regards,
>> Aker Br
Re: How to get LPG to treat comments as terminals [message #574435 is a reply to message #25730] |
Hi Aker,
%Rules
Stan
Aker wrote:
> when I hover over a
> Aker
>> Hello Acker,
>> achieve?
>> Thanks,
>> Stan
>>> regards,
>>> Aker Brückler
Re: How to get LPG to treat comments as terminals [message #574465 is a reply to message #25765] |
Hi Stan,
macros)?
BR
Aker
> Hi Aker,
> %Rules
> array.
> Stan
> Aker wrote:
>> Regards,
>> Aker
>>> Hello Acker,
>>> achieve?
>>> Thanks,
>>> Stan
>>>> regards,
>>>> Aker Br
Re: How to get LPG to treat comments as terminals [message #574494 is a reply to message #25776] |
Hi Aker,
%Headers
%end
%Rules
sayHello();
Stan
Aker wrote:
> Hi Stan,
> macros)?
> BR
> Aker
>> Hi Aker,
>> %Rules
>> array.
>> Regards,
>> Stan
>> Aker wrote:
>>> Hi,
>>> Regards,
>>> Aker
>>>> Hello Acker,
>>>> achieve?
>>>> Thanks,
>>>> Stan
>>>>> regards,
>>>>> Aker Brückler
Re: How to get LPG to treat comments as terminals [message #574513 is a reply to message #25730] |
Tue, 25 November 2008 01:16  |
Hi Aker
I've been thinking about this from a different requirement: refactoring
and a reverse engineeering update.
In the AST it is easy to identify all semantically equivalent re-uses of
the same name, so the AST can be changed, but that must be reverse
engineered into the source text again, which requires preservation of
the comments.
I think it's a mistake to make comments first class terminals, since
then every production must have COMMENTopt between every terminal.
Ed Willink
Re: How to get LPG to treat comments as terminals [message #575068 is a reply to message #25841] |
int a; // A
// B
/* C */
* D
// E
int e;
Ed Willink
Current Time: Tue May 13 12:44:34 EDT 2025
Powered by FUDForum. Page generated in 0.09702 seconds
