Eclipse + Cygwin + Contiki RTOS [message #258268] |
Thu, 12 June 2008 09:04  |
Originally posted by: jimmytmathew.yahoo.co.uk
I am using Contiki RTOS for my application. I have Eclipse 3.3.2 with
latest Cygwin compiler. The Contiki produces executable in ".native" form
(it is equivalent to ".exe").
My problem is I can use Cygwin bash terminal to execute and view the
result. But I am not able to view the same result when I use Cygwin with
Eclipse. When I try to run the program in Eclipse, I always get a blank
screen. Can anybody trace the problem?
Jimmy
Re: Eclipse + Cygwin + Contiki RTOS [message #258453 is a reply to message #258447] |
Fri, 13 June 2008 08:48  |
I have problems with eclipse/cygwin and Mingw.
I see that you seem to get a good result with Contiki RTOS so why bother
with eclipse if Contiki works?
I give my problem below for information, if you can help with it?
1.Ive just downloaded
eclipse-cpp-europa-winter-win32, mingw
I compiled and ran the intro."Hello
World" prog. ok.
However, when I try to build and run
it again as the same program,
I get the following error :
**** Internal Builder is used for
build ****
gcc -O0 -g3 -Wall -c
-fmessage-length=0 -osrc\helloworld.o
\src\helloworld.c
gcc: installation problem, cannot
exec `cc1': No such file or directory
Build error occurred, build is
stopped
Time consumed: 125 ms.
2.repeat the process with new name
Hello World 2: error:"Nothing to
build"
3.repeat with Hello World3 same result
More information:
Also as I try and work thro. other
projects they seem to get mixed up with
each
other, and the runs fail.
Error messages are "launch failed no
binaries" etc.
Is there a way of clearing failed
projects from the platform completely?
I have printed out several tutorials
but they dont ans. this.
I may say that eclipse came as a breath
of fresh air after the useless Borland
C++ compiler and the worse Microsoft
Net framework 3.5 and vis C++ x 86!
However there are still problems.
Is this a problem with MinGW, not
Eclipse?
Or Windows xp with the MinGW compiler?
Further Comment #2 From Brian Southey
2008-06-13
When I started using eclipse I had a
choice of toolchain:
cygwin or MinGW.
The eclipse tutorial said to use cygwin
and not MinGW.
My prog. ran successfully.
When I tried again the cygwin tool was
"not available on this platform" so I
had to select MinGW.
From then on all seven of my projects
have either failed to launch or given
the
cc1 error.
I joined the MinGW user mailing list
and within 2 days had received 140
emails
from them about problems with their
MinGW!!!
I had to close the link but before this
I did NOT get any help with MY problem.
All of this seems to indicate that
MinGW is very difficult to use.
Can I uninstall Mingw and eclipse and
unzip the zip version of eclipse?
Brian.
FUDForum. Page generated in 0.10035 seconds
