Home » Newcomers » Newcomers » No event occured at ScaleFieldEditor with mouse wheel
No event occured at ScaleFieldEditor with mouse wheel [message #258263] Thu, 12 June 2008 08:33 Go to next message
Hello.
I found the subject issue on SWT/JFace version 3.3.2.
The following source code includes the issue.
import java.io.IOException;
import org.eclipse.jface.preference.FieldEditor;
import org.eclipse.jface.preference.IPreferencePageContainer;
import org.eclipse.jface.preference.PreferenceDialog;
import org.eclipse.jface.preference.PreferenceManager;
import org.eclipse.jface.preference.PreferenceNode;
import org.eclipse.jface.preference.PreferencePage;
import org.eclipse.jface.preference.ScaleFieldEditor;
import org.eclipse.jface.util.IPropertyChangeListener;
import org.eclipse.jface.util.PropertyChangeEvent;
import org.eclipse.swt.SWT;
import org.eclipse.swt.layout.GridData;
import org.eclipse.swt.layout.GridLayout;
import org.eclipse.swt.widgets.Composite;
import org.eclipse.swt.widgets.Control;
import org.eclipse.swt.widgets.Shell;
public class NoEvent extends PreferenceDialog {
public NoEvent(Shell parentShell, PreferenceManager manager) throws
IOException {
super(parentShell, manager);
PreferencePage page1 = new SamplePreferencePage("Page1", this);
PreferenceNode node1 = new PreferenceNode("node1", page1);
manager.addToRoot(node1);
private final class SamplePreferencePage extends PreferencePage {
private FieldEditor editor;
private SamplePreferencePage(String title,
IPreferencePageContainer container) {
super(title);
setContainer(container);
protected Control createContents(Composite parent) {
Composite composite = new Composite(parent, SWT.NONE);
composite.setLayout(new GridLayout(2, false));
composite.setLayoutData(new
GridData(GridData.FILL_HORIZONTAL));
editor = new ScaleFieldEditor("scale", "&Scale", composite);
editor.setPage(this);
editor.setPreferenceStore(getPreferenceStore());
editor.load();
editor.setPropertyChangeListener(new IPropertyChangeListener()
public void propertyChange(PropertyChangeEvent event) {
// Event occured when scale editor was clicked.
// However, no event occured when scale value changed
with mouse wheel.
System.out.println("event occured");
return parent;
public static void main(String[] args) throws IOException {
Display display = new Display();
Shell shell = new Shell(display);
NoEvent dialog = new NoEvent(shell, new PreferenceManager());
dialog.open();
shell.dispose();
while (!shell.isDisposed()) {
if (!display.readAndDispatch()) {
display.sleep();
display.dispose();
I think this is a bug.
Should I report to Bugzilla this issue?
Re: No event occured at ScaleFieldEditor with mouse wheel [message #258481 is a reply to message #258263] Fri, 13 June 2008 10:00 Go to previous messageGo to next message
I assume that you mean the "mouse wheel" issue mentioned in the
comments.
First, I recommend that you include a few words describing the problem
before the code (so that the reader doesn't have to hunt for it).
Second, it does sound like a bug. Please report it.
Wayne
On Thu, 2008-06-12 at 12:33 +0000, Satoshi OGATA wrote:
> Hello.
> import org.eclipse.swt.widgets.Display;
> IOException {
> super(title);
> @Override
> editor.load();
> @Override
> with mouse wheel.
> return parent;
> dialog.open();
> shell.dispose();
> display.sleep();
> display.dispose();
Re: No event occured at ScaleFieldEditor with mouse wheel [message #258488 is a reply to message #258481] Fri, 13 June 2008 10:02 Go to previous messageGo to next message
FWIW, I apparently have "Subject line" blindness.
Wayne
Re: No event occured at ScaleFieldEditor with mouse wheel [message #258586 is a reply to message #258488] Sat, 14 June 2008 11:04 Go to previous message
Thank you for your comments.
I was nervous because I have a experience of non-bug reporting before.
I'll try to report this issue.
OGATA
Previous Topic:Eclipse Apache Derby
Next Topic:Managment Tool
Current Time: Wed Jul 30 19:11:12 EDT 2025
Powered by FUDForum. Page generated in 0.28978 seconds
