Home » Archived » BIRT » why script error on simple hyperlink to bookmark ?
why script error on simple hyperlink to bookmark ? [message #258065] Fri, 12 October 2007 10:25 Go to next message
Originally posted by: peter.marx.knorr-bremse.com
I created two labels, setting the bookmark of #2 to <target> and defining
in #1 a hyperlink by selecting the same report and selecting the offered
bookmark named target.
This produces linktest.rptdesign:target in the properties "link to" field.
Hyperlink type is Drill-Through (same effect happens when "Internal
Bookmark")
In preview the hyperlink works properly, but I get this error text:
The following items have errors:
ReportDesign (id = 1):
+ There are errors evaluating script "target":{1}.
What is wrong here ?
Re: why script error on simple hyperlink to bookmark ? [message #258080 is a reply to message #258065] Fri, 12 October 2007 11:32 Go to previous messageGo to next message
Peter,
Make sure your target is in quotes and then rebuild the link. This
should be an internal bookmark.
Attached is an example.
Jason
<report xmlns="http://www.eclipse.org/birt/2005/design" version="3.2.14"
id="1">
<property name="createdBy">Eclipse BIRT Designer Version
2.2.0.v20070620 Build &lt;2.2.0.v20070626-1003></property>
<property name="units">in</property>
<property name="comments">Copyright (c) 2007 &lt;&lt;Your Company
Name here>></property>
<html-property name="description">Creates a blank report with no
predefined content.</html-property>
<text-property name="displayName">Blank Report</text-property>
<property name="iconFile">/templates/blank_report.gif</property>
<styles>
<style name="crosstab" id="4">
<property name="borderBottomColor">#CCCCCC</property>
<property name="borderBottomStyle">solid</property>
<property name="borderBottomWidth">1pt</property>
<property name="borderLeftColor">#CCCCCC</property>
<property name="borderLeftStyle">solid</property>
<property name="borderLeftWidth">1pt</property>
<property name="borderRightColor">#CCCCCC</property>
<property name="borderRightStyle">solid</property>
<property name="borderRightWidth">1pt</property>
<property name="borderTopColor">#CCCCCC</property>
<property name="borderTopStyle">solid</property>
<property name="borderTopWidth">1pt</property>
</style>
<style name="crosstab-cell" id="5">
</style>
</styles>
<page-setup>
<simple-master-page name="Simple MasterPage" id="2">
<page-footer>
<text id="3">
<property name="contentType">html</property>
<text-property
name="content"><![CDATA[<value-of>new Date()</value-of>]]></text-property>
</text>
</page-footer>
</simple-master-page>
</page-setup>
<body>
<label id="6">
<property name="pageBreakAfter">always</property>
<text-property name="text">Label 1</text-property>
<structure name="action">
<property name="linkType">bookmark-link</property>
<expression name="targetBookmark">"test"</expression>
</structure>
</label>
<label id="7">
<expression name="bookmark">"test"</expression>
<text-property name="text">Label 2</text-property>
</label>
</body>
</report>
> defining in #1 a hyperlink by selecting the same report and selecting
> the offered bookmark named target.
> Bookmark")
> ReportDesign (id = 1): + There are errors evaluating script
> "target":{1}. ---------------------------------------------------------
Re: why script error on simple hyperlink to bookmark ? [message #258084 is a reply to message #258080] Fri, 12 October 2007 11:54 Go to previous message
Hi Jason,
it works!
Was not so obvious from help that ".." is necessary.
Thanks a lot
Peter
Previous Topic:why IdataExtractionTask.getResultSetList( ); returns ONLY ONE ResultSet?
Next Topic:Help regarding script
Current Time: Sun Oct 26 16:46:08 EDT 2025
Powered by FUDForum. Page generated in 0.44995 seconds
