How best to use with Java Packages? [message #258053] |
Tue, 10 June 2008 15:58  |
I have been happily using Eclipse for a few years but I think I setup my
projects in a "Brute Force" manner. I played around until I got something
to work and did cut and paste to move my .java files to my configuration
management folders from source folders in my projects area.
I am installing version 3.3.2 and decided to use the tool more wisely.
I've played with it for a couple days and remain frustrated.
Let me state my situation and objectives.
Situation:
I am developing 2 Java packages [pk_1 and pk_2] designed for use in Java
Stand=Alone Apps.
Ideally, the code resides in the following folders:
C:/com/pk_1/
C:/com/pk_2/
I also have a folder that contains the .jar files used by one or both of
these packages:
C:/classLibraries/
Objective:
Use Eclipse to develop and test these packages:
What I have been trying to figure out is how to do the following:
1) Create a development project for each Java Package to reference the
above folders and produce a pk_1.jar and pk_1.jar file.
2) Create test projects that use the pk_1.jar and pk_2.jar files as
follows:
a) Project Test pk_1: Stand-Alone program using pk_1.jar.
b) Project Test pk_2: Stand-Alone program using pk_2.jar.
c) Project Test pk_1_2: Stand-Alone program using pk_1.jar and
pk_2.jar.
Note: the .java class used in the above projects would be hosted in the
Eclipse 3.3.2 workspace holder.
I have come close to the setting up one of the packages but the
compilation fails on my "import com.pk_1" statement saying the package was
not a expected.
I'm going around in circles and need some advise.
Jim...
Re: How best to use with Java Packages? [message #258231 is a reply to message #258177] |
Thu, 12 June 2008 04:07   |
Originally posted by: 4cs6fcg02.sneakemail.com
This is an OpenPGP/MIME signed message (RFC 2440 and 3156)
--------------enigC57737F119DC36F01E2114C9
Content-Type: text/plain; charset=UTF-8; format=flowed
Jim Crowell schreef:
> Dave Wegener responded:
>> Check out the project configuration tutorial in the Java Development U=
ser
>> Guide in Help Contents. It is in the Getting Started section. The=20
>> tutorial
>> discusses several types of projects and how to set them up depending=20
>> on your
>> preferences.
>=20
> Thanks Dave.
> I have been there before but the resultant project gave me errors about=
=20
> an unexpected Java package name.
>=20
> I did not use it as directed however. I was trying to use the=20
> C:/com/pk_1/ folder as my source.
>=20
> It looks to me like I can not do as I wanted.
> I have to put my source code in a c:/pk_1/source/com/pk_1/ folder to=20
> produce a .jar where the end user will use the following desired import=
=20
> statement:
> import com.pk_1.*;
>=20
> This is OK in that I still have a folder outside the Eclipse Project=20
> workspace that contains my Latest Java code for cm purposes.
>=20
> In all my Eclipse setup reading, I never saw anything telling me how to=
=20
> setup for a "com.packageName" development.
>=20
> Several years ago, before using Eclipse, I used EMacs and setup package=
s=20
> in c:/com/packageName folders and I always thought there must be away t=
o=20
> do the same with Eclipse.
>=20
> Just stubborn I guess!
When making a new Java project, Eclipse 3.3 will ask you where to put=20
it. You can take C: as a location although I would not recommend it=20
(this is what you are doing now: your Java setup is directly under C:,=20
you have to consider the com/ directory as part of the filename, sort=20
of). I=E2=80=99d recommend you make it C:/workspace or something.
Then, if you use the new class wizard, and give as package=20
com.packageName or class Test, Eclipse will automatically create the=20
directories com/packageName and put a file called Test.java there.
You can then, once you have the new project, import from existing=20
sources; choose the folder C: and check the com/ directory. That should =
do it.
Provided, of course, that your classes in com/pk_1/ all have a=20
declaration =E2=80=98package com.pk_1=E2=80=99.
Note that in the project properties, you can reference other Java=20
projects, which means that for example for the test projects, you don=E2=80=
=99t=20
need to put pk_1.jar in the classpath, but you can refer to the classes=20
directly. Nothing prevents you from including the jar, though.
H.
--=20
Hendrik Maryns
http://tcl.sfs.uni-tuebingen.de/~hendrik/
=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D
http://aouw.org
Ask smart questions, get good answers:
http://www.catb.org/~esr/faqs/smart-questions.html
Content-Type: application/pgp-signature; name="signature.asc"
Content-Description: OpenPGP digital signature
Content-Disposition: attachment; filename="signature.asc"
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v2.0.4-svn0 (GNU/Linux)
Comment: Using GnuPG with SUSE - http://enigmail.mozdev.org
iD8DBQFIUNkze+7xMGD3itQRAtZhAJ9ymLZR6Fo0ib6JnGOC2Nc0LpwiMACe IfAH
zP2iwruqx+9CIVRq+fubFdc=
=HxRS
-----END PGP SIGNATURE-----
--------------enigC57737F119DC36F01E2114C9--
Re: How best to use with Java Packages? [message #258243 is a reply to message #258231] |
Thu, 12 June 2008 04:58  |
>>> User
>>> tutorial
>>> on your
>>> preferences.
>> Thanks Dave.
>> about an unexpected Java package name.
>> import statement:
>> import com.pk_1.*;
>> to setup for a "com.packageName" development.
>> packages in c:/com/packageName folders and I always thought there
>> must be away to do the same with Eclipse.
I doubt this works as this would overlap with the workspace location.
> although I would not recommend it (this is what you are doing now:
> your Java setup is directly under C:, you have to consider the com/
> directory as part of the filename, sort of). I’d recommend you make
Or simply move your source into its own folder, e.g. c:\source. Then you
can have your eclipse workspace anywhere on C:, create a Java project
and then add a source folder that links to c:\source.
Dani
> should do it.
> declaration ‘package com.pk_1’.
> don’t need to put pk_1.jar in the classpath, but you can refer to the
> classes directly. Nothing prevents you from including the jar, though.
> H.
FUDForum. Page generated in 0.11263 seconds
