Home » Eclipse Projects » Eclipse Platform » Strange JNI Problem
Strange JNI Problem [message #258051] Fri, 02 July 2004 18:51 Go to next message
Originally posted by: barlock.usDOT.ibmDOT.com
I refactored some code, changing Java package names. Some of this code is
JNI. I recompiled all the Java and native code and am now getting an
unsatisfied link error on the first call to the native code. In debugging
this, I notice that the "old" DLL has this in it:
_Java_com_ibm_tivoli_monitoring_workbench_util_JNIUtils_gete nv @12
and the "new" DLL has this:
Java_com_ibm_tivoli_rmb_model_workbench_util_JNIUtils_getenv
In the debugger, I get in to Classloader.findNative and see that the second
parameter, name is:
_Java_com_ibm_tivoli_rmb_model_workbench_util_JNIUtils_geten v @12
I'm not sure whether this is the source of the problem or a red
herring...and I don't know why the "old" DLL has this "@12" and the
underscore before "Java" but the new one does not. Does this mean anything
to anyone?
Chris
Re: Strange JNI Problem [message #258055 is a reply to message #258051] Fri, 02 July 2004 19:03 Go to previous messageGo to next message
> parameter, name is:
> to anyone?
Absolutely. This type of function name mangling will cause
UnsatisfiedLineErrors. However, I am puzzled by your description.
Typically, the function *with* the @xx decoration causes this type of error.
What C/C++ compiler are you using?
Jim S.
> Chris
Re: Strange JNI Problem [message #258059 is a reply to message #258055] Fri, 02 July 2004 19:32 Go to previous messageGo to next message
error.
Microsoft Visual C 6.0 with SP5. Why does this name mangling occur and how
to I correct this problem? The old and new versions of the DLL were built
with the same compiler.
Chris
Re: Strange JNI Problem [message #258172 is a reply to message #258059] Sun, 04 July 2004 04:53 Go to previous messageGo to next message
> error.
> Chris
Have you changed the type of compile, i.e. from C to C++ or vica verse?
Typically the name mangling will be introduced by the C++ compiler.
C++ will automatically switch to C++ if the sourcefile has a postfix of
'.cpp'. I had the same problem before and after moving my code from a
'.c' file to a '.cpp' file and recompiling everything was ok.
Hope this helps.
Re: Strange JNI Problem [message #258264 is a reply to message #258172] Sun, 04 July 2004 19:13 Go to previous messageGo to next message
"Lothar Joeckel" <ljoeckel@t-online.de> wrote in message
news:cc8gm3$evj$1@eclipse.org...
> > error.
how
built
> > Chris
> Hope this helps.
No, the source is a set of .cpp files and I haven't changed any of the
native code -- only the Java code. However one difference: in the version
that works, the Java code was compiled with JDK 1.3.0. My new version was
built with JDK 1.4.1. Could that be significant?
Chris
Re: Strange JNI Problem [message #258277 is a reply to message #258264] Sun, 04 July 2004 21:29 Go to previous message
>>>error.
> how
> built
>>>Chris
>>Hope this helps.
> Chris
I'm not sure if you have to regenerate the C Header and Stub files
with 'javah'. Eventually something has changed between these
different jdk-versions.
Lothar
Previous Topic:Porting to 3.0 & Eclipse's complexity
Next Topic:How to make editor resource content type aware?
Current Time: Sun Aug 31 18:32:02 EDT 2025
Powered by FUDForum. Page generated in 0.11203 seconds
