Home » Eclipse Projects » SWTBot » Improvement for captureScreenshot
Improvement for captureScreenshot [message #25499] |
Tue, 03 March 2009 11:09  |
Hi Ketan,
Thanks so much for SWTBot; I'm using it for a couple of weeks, and it
gives me a lot of satisfaction.
The project I'm working on has a GUI which is changing from day to day,
because it's for research purposes. I have thought SWTbot could also
helped me to maintain up to date the screenshots of the documentation.
Unfortunately, it is not possible to take the screenshoot of a single
shell, or tabfolder. Would it be possible to add a method like this one?
public static boolean captureScreenshot(final String fileName, Widget
widget)
Etienne
Re: Improvement for captureScreenshot [message #25537 is a reply to message #25499] |
Tue, 03 March 2009 11:52   |
Hi Etienne,
This is very much possible. Take a look at
SWTUtils#captureScreenshotInternal for how the screenshot works. It
works by taking the entire display and dumping the content into an image
object.
What you need instead to do to take the widget instead of the display,
and you should be done.
-- Ketan
On 3/3/09 21:39, Etienne wrote:
> Hi Ketan,
> widget)
> Etienne
Re: Improvement for captureScreenshot [message #26049 is a reply to message #25537] |
Wed, 04 March 2009 09:32   |
here is a sample usage of SWTBot to generate the documentation images:
http://model-driven-blogging.blogspot.com/2009/03/shuangxi-e ffect-ui-
testing-and.html
and here is the code to capture the "active shell screenshot"
* This captures a screen shot and saves it to the given file.
* @param fileName
* the filename to save screenshot to.
* @return <code>true</code> if the screenshot was created and saved,
* <code>false</code> otherwise.
* @since 1.0
public static boolean captureScreenshot(final String fileName) {
new ImageFormatConverter().imageTypeOf(fileName.substring(fileNa me
.lastIndexOf('.') + 1));
return UIThreadRunnable.syncExec(new BoolResult() {
public Boolean run() {
return captureScreenshotInternal("screenshots/"+fileName,
Display.getDefault()
.getActiveShell());
* Captures a screen shot. Used internally.
* <p>
* NOTE: This method is not thread safe. Clients must ensure that they do
* invoke this from a UI thread.
* </p>
* @param fileName
* @param widget
* @since 1.1
protected static boolean captureScreenshotInternal(final String fileName,
Shell widget) {
GC gc = new GC(Display.getDefault());
Image image = null;
try {
Rectangle bounds = widget.getBounds();
int width = bounds.width;
int height = bounds.height;
image = new Image(Display.getDefault(), width, height);
gc.copyArea(image, bounds.x, bounds.y);
ImageLoader imageLoader = new ImageLoader();
imageLoader.data = new ImageData[] { image.getImageData() };
imageLoader.save(fileName, new ImageFormatConverter()
.substring(fileName.lastIndexOf('.') + 1)));
return true;
} catch (Exception e) {
File brokenImage = new File(fileName).getAbsoluteFile();
if (brokenImage.exists()) {
try {
brokenImage.deleteOnExit();
} catch (Exception ex) {
return false;
} finally {
gc.dispose();
if (image != null) {
image.dispose();
cheers,
Cédric
Ketan Padegaonkar wrote:
> Hi Etienne,
> object.
> -- Ketan
>> Hi Ketan,
>> widget)
>> Regards,
>> Etienne
Re: Improvement for captureScreenshot [message #26132 is a reply to message #26049] |
Wed, 04 March 2009 11:50   |
Thank you very much, Ketan and Cédric,
I have made something which looks like Cédric's code. I have just made
things a bit more generic, with parameter Control instead of Shell.
(my code below)
Etienne
fileName, final Control control) {
GC gc = new GC(display());
Image image = null;
try {
//Rectangle bounds = display().getBounds();
//int width = bounds.width;
//int height = bounds.height;
int width = control.getBounds().width;
int height = control.getBounds().height;
Point p = control.toDisplay(0, 0);
image = new Image(display(), width, height);
gc.copyArea(image, p.x, p.y);
(...) // No more modifications after this line.
Cédric Brun a écrit :
> testing-and.html
> * @param fileName
> * @since 1.0
> .getActiveShell());
> * <p>
> * </p>
> * @param fileName
> * @param widget
> * @since 1.1
> Shell widget) {
> Image image = null;
> try {
> return true;
> try {
> return false;
> } finally {
> gc.dispose();
> image.dispose();
> cheers,
> Cédric
>> Hi Etienne,
>> object.
>> -- Ketan
>>> Hi Ketan,
>>> widget)
>>> Regards,
>>> Etienne
Re: Improvement for captureScreenshot [message #26174 is a reply to message #26049] |
Wed, 04 March 2009 12:22   |
Could you attach this to the bugzilla, and I could add this as an API to
SWTBot :)
-- Ketan
On 4/3/09 20:02, Cédric Brun wrote:
> testing-and.html
> * @param fileName
> * @return<code>true</code> if the screenshot was created and saved,
> *<code>false</code> otherwise.
> * @since 1.0
> .getActiveShell());
> *<p>
> *</p>
> * @param fileName
> * @param widget
> * @since 1.1
> Shell widget) {
> Image image = null;
> try {
> return true;
> try {
> return false;
> } finally {
> gc.dispose();
> image.dispose();
> cheers,
> Cédric
>> Hi Etienne,
>> object.
>> -- Ketan
>>> Hi Ketan,
>>> widget)
>>> Regards,
>>> Etienne
Re: Improvement for captureScreenshot [message #26257 is a reply to message #26174] |
Thu, 05 March 2009 08:05   |
No problem, I'm going to add it to bugzilla.
Etienne
Ketan Padegaonkar a écrit :
> SWTBot :)
> -- Ketan
>> testing-and.html
>> * @param fileName
>> * @since 1.0
>> new
>> .getActiveShell());
>> *<p>
>> they do
>> *</p>
>> * @param fileName
>> * @param widget
>> * @since 1.1
>> fileName,
>> Shell widget) {
>> Image image = null;
>> try {
>> return true;
>> try {
>> return false;
>> } finally {
>> gc.dispose();
>> image.dispose();
>> cheers,
>> Cédric
>>> Hi Etienne,
>>> object.
>>> -- Ketan
>>>> Hi Ketan,
>>>> one?
>>>> widget)
>>>> Regards,
>>>> Etienne
Re: Improvement for captureScreenshot [message #26984 is a reply to message #26447] |
Tue, 10 March 2009 06:14  |
After some other tests, I have found a problem in my implementation.
In method :
public static boolean captureScreenshot(final String fileName, final
Control control)
The line :
Gives good coordinates for widgets *except* for shells which have a border.
In this special case, the toDisplay method returns the first point on
the top left corner inside the borders of the wigets, whereas we would
like to get the point on the top left corner of the System title bar of
the window.
I think we could change the line :
into :
if (control.getClass() == Shell.class)
p = control.getLocation();
else
I'm not expert enough in SWT to say if it's the best way to get correct
screenshot areas...
Etienne
--> https://bugs.eclipse.org/bugs/show_bug.cgi?id=267189
> Fixed and committed to trunk, as some added goodness, you can now
> capture just about any rectangular region on the screen.
> -- Ketan
> On 5/3/09 20:43, Chris Aniszczyk wrote:
>> Do you have a bug number?
>> Cheers,
>> Chris Aniszczyk | EclipseSource Austin | +1 860 839 2465
>> http://twitter.com/eclipsesource | http://twitter.com/caniszczyk
Current Time: Tue Jun 17 14:34:23 EDT 2025
Powered by FUDForum. Page generated in 0.10266 seconds
