Home » Archived » BIRT » ODA driver for Bugzilla
ODA driver for Bugzilla [message #258048] Fri, 12 October 2007 08:34 Go to next message
Any one ever see any BIRT ODA driver for bugzilla, Which can be used to
access data from bugzilla in BIRT reports? Or is there any other easy way
to access bugzilla data in BIRT reports?
Need this for an urgent demo...any help will be appreciated!
Re: ODA driver for Bugzilla [message #258128 is a reply to message #258048] Fri, 12 October 2007 14:44 Go to previous messageGo to next message
Xiang,
I have not seen one, but I think you can download the data in CSV and
use the flat file driver or import to a db.
Jason
> way to access bugzilla data in BIRT reports?
Re: ODA driver for Bugzilla [message #258211 is a reply to message #258128] Fri, 12 October 2007 16:18 Go to previous messageGo to next message
Below is an example of reporting of Bugzilla from MySQL
http://www.birt-exchange.com/modules/wfdownloads/singlefile. php?cid=2&lid=46
I have also created reports from the Bugzilla feeds, you can use the CSV
feed with the BIRT Flat file data source... or the RSS feed with the
BIRT XML data source.
Virgil Dodson
Jason Weathersby wrote:
> Xiang,
> Jason
>> to access data from bugzilla in BIRT reports? Or is there any other
>> easy way to access bugzilla data in BIRT reports?
Re: ODA driver for Bugzilla [message #258382 is a reply to message #258048] Mon, 15 October 2007 12:08 Go to previous messageGo to next message
Xiang,
Jason and Virgil have great answers all ready. By far the easiest way to
report on Bugzilla using BIRT is to just attach to the MySQL database that
backs up Bugzilla (See Virgil's post).
If you don't have access to the Bugzilla database, then you have to use the
export options to get the data as a comma seperated value feed or an RSS
feed. This technique will work, but is not nearly as neat and tidy as connecting
directly to the DB.
If you want to use the exports as CSV, and you want to make it neat and tidy,
that is when you need to create an ODA. Depending on what you want to do,
and your experience with Eclipse, this can be any where from a trivial to
a mind-bending experience.
Scott Rosenbaum
> to
> way
Re: ODA driver for Bugzilla [message #258434 is a reply to message #258382] Tue, 16 October 2007 01:46 Go to previous message
This is a multipart message in MIME format.
--=_alternative 001FB2CF48257376_=
Content-Type: text/plain; charset="US-ASCII"
Thanks Scott! and Thanks Jason and Virgil for all of our kind help!
I can build a report with exported XML/CSV for presentation fow now.
Will consider about building ODA driver later if we really need it.
Content-Type: text/html; charset="US-ASCII"
<br><font size=2 face="sans-serif">Thanks Scott! and Thanks Jason and Virgil
for all of our kind help!</font>
<br>
<br><font size=2 face="sans-serif">I can build a report with exported XML/CSV
for presentation fow now.</font>
<br><font size=2 face="sans-serif">Will consider about building ODA driver
later if we really need it.</font>
--=_alternative 001FB2CF48257376_=--
Previous Topic:Birt 2.2 Tag Library secure nonsecure items warning
Next Topic:How to embed rtf docs in to BIRT Report Designs
Current Time: Mon Jul 21 21:23:56 EDT 2025
Powered by FUDForum. Page generated in 0.05484 seconds
