Home » Eclipse Projects » Buckminster dev » Re: [buckminster-dev] PDE headless build of RCP headless product ... "The System Bundle's start
Re: [buckminster-dev] PDE headless build of RCP headless product ... "The System Bundle's start [message #25497] Fri, 19 September 2008 01:53
Hi Ki,
Do you have a custom config.ini file for you RCP app?
Are you using Buckminster for 3.3 or 3.4?
Thomas Hallgren
Ki Alam wrote:
> Hi there.
> We are trying to transition our build from the PDE headless build to
> the buckminster headless build. We got through the resolve bits and
> are able to build , but when trying to run the build, we get the
> following error:
> !SESSION 2008-09-18 05:18:19.011
> eclipse.buildId=unknown
> java.version=1.6.0_03
> java.vendor=Sun Microsystems Inc.
> BootLoader constants: OS=linux, ARCH=x86, WS=gtk, NL=en_US
> !ENTRY org.eclipse.osgi 4 0 2008-09-18 05:18:19.654
> !MESSAGE An unexpected runtime error has occurred.
> !STACK 0
> java.lang.IllegalArgumentException: The System Bundle's start level
> can not be modified.
> at
> org.eclipse.osgi.framework.internal.core.StartLevelManager.s etBundleStartLevel(StartLevelManager.java:415)
> at
> org.eclipse.core.runtime.adaptor.EclipseStarter.installBundl es(EclipseStarter.java:1117)
> at
> org.eclipse.core.runtime.adaptor.EclipseStarter.loadBasicBun dles(EclipseStarter.java:642)
> at
> org.eclipse.core.runtime.adaptor.EclipseStarter.access$1(Ecl ipseStarter.java:619)
> at
> org.eclipse.core.runtime.adaptor.EclipseStarter$1.bundleChan ged(EclipseStarter.java:308)
> at
> org.eclipse.osgi.framework.internal.core.BundleContextImpl.d ispatchEvent(BundleContextImpl.java:1234)
> at
> org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEve nt(EventManager.java:211)
> at
> org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEv entSynchronous(ListenerQueue.java:141)
> at
> org.eclipse.osgi.framework.internal.core.Framework.publishBu ndleEventPrivileged(Framework.java:1518)
> at
> org.eclipse.osgi.framework.internal.core.Framework.publishBu ndleEvent(Framework.java:1469)
> at
> org.eclipse.osgi.framework.internal.core.StartLevelManager.d oSetStartLevel(StartLevelManager.java:281)
> at
> org.eclipse.osgi.framework.internal.core.StartLevelManager.l aunch(StartLevelManager.java:247)
> at
> org.eclipse.osgi.framework.internal.core.SystemBundle.resume (SystemBundle.java:201)
> at
> org.eclipse.osgi.framework.internal.core.Framework.launch(Fr amework.java:644)
> at
> org.eclipse.osgi.framework.internal.core.OSGi.launch(OSGi.ja va:51)
> at
> org.eclipse.core.runtime.adaptor.EclipseStarter.startup(Ecli pseStarter.java:313)
> at
> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:175)
> at
> sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39)
> at
> sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:25)
> at java.lang.reflect.Method.invoke(Method.java:597) at
> org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 549)
> at
> org.eclipse.equinox.launcher.Main.basicRun(Main.java:504) at
> org.eclipse.equinox.launcher.Main.run(Main.java:1236)
> at org.eclipse.equinox.launcher.Main.main(Main.java:1212)
> !ENTRY org.eclipse.osgi 4 0 2008-09-18 05:18:19.655
> !MESSAGE
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> !ENTRY org.eclipse.osgi 4 0 2008-09-18 05:18:19.656
> !MESSAGE Application error
> !STACK 1
> java.lang.IllegalStateException: Platform not running
> at
> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:370)
> at
> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
> Followed by the bundles not being able to be resolved:
> !ENTRY org.eclipse.osgi 2 0 2008-09-18 05:18:19.677
> !MESSAGE One or more bundles are not resolved because the following
> root constraints are not resolved:
> !SUBENTRY 1 org.eclipse.osgi 2 0 2008-09-18 05:18:19.677
> !MESSAGE Bundle
> initial@reference:file:plugins/m365.agent.logmessageservice_1.0.0.jar/
> was not resolved.
> !SUBENTRY 2 m365.agent.logmessageservice 2 0 2008-09-18 05:18:19.678
> !MESSAGE Missing required bundle wily.introscope.em_0.0.0.
> !SUBENTRY 1 org.eclipse.osgi 2 0 2008-09-18 05:18:19.678
> !MESSAGE Bundle
> initial@reference :file:plugins/m365.embeddedem.datacenter.properties_1.0.0.ja r/
> was not resolved.
> !SUBENTRY 2 m365.embeddedem.datacenter.properties 2 0 2008-09-18
> 05:18:19.678
> !MESSAGE Missing host wily.introscope.em_1.0.0.
> !MESSAGE Bundle
> initial@reference:file:plugins/m365.messaging.transport.sender_1.0.0.jar/
> was not resolved.
> !SUBENTRY 2 m365.messaging.transport.sender 2 0 2008-09-18 05:18:19.678
> !MESSAGE Missing imported package m365_0.0.0.
> !MESSAGE Bundle
> initial@reference:file:plugins/m365.agent.classanalysis.isengard_1.0.0.jar/
> was not resolved.
> !SUBENTRY 2 m365.agent.classanalysis.isengard 2 0 2008-09-18 05:18:19.678
> !MESSAGE Bundle
> initial@reference:file:plugins/m365.isengard_1.0.0.jar/ was not resolved.
> !SUBENTRY 2 m365.isengard 2 0 2008-09-18 05:18:19.678
> We are able to build using the existing PDE-headless build ... has
> anyone run into this?
> Ki
> _______________________________________________
> buckminster-dev mailing list
> buckminster-dev@eclipse.org
> https://dev.eclipse.org/mailman/listinfo/buckminster-dev
Previous Topic:[buckminster-dev] PDE headless build of RCP headless product ... "The System Bundle's start lev
Next Topic:Re: [buckminster-dev] PDE headless build of RCP headless product ... "The System Bundle's start
Current Time: Sun May 11 21:03:34 EDT 2025
Powered by FUDForum. Page generated in 0.03203 seconds
