Home » Archived » BIRT » lower - upper case in column names are a problem
lower - upper case in column names are a problem [message #257898] Thu, 11 October 2007 03:08
Originally posted by: lamprecht.bwdesign.de
hi,
there are mysql db´s with the same table but in the column names are
lower case chars and in other uppercase by the same column, in mysql
it´s no problem.
in birt 2.2.0 it is
the message:
data.engine.ColumnBindingReferToInexistColumn ( 5 time(s) )
detail : org.eclipse.birt.data.engine.core.DataException: Column binding
"zwert_FANT_BAUCH_3" has referred to a data set column
"zwert_FANT_BAUCH_3" which is not exist. at
org.eclipse.birt.data.engine.impl.ResultIterator.validateMan ualBindingExpressions(ResultIterator.java:290)
org.eclipse.birt.data.engine.impl.ResultIterator.<init>(ResultIterator.java:144)
the col exists as ZWERT_FANT_BAUCH_3
mfg
Norbert Lamprecht
Previous Topic:Best Way to Hide and Disable a Chart/Table?
Next Topic:Total.count or aggregation count do not return zero when a table is empty
Current Time: Sun Oct 26 21:04:30 EDT 2025
Powered by FUDForum. Page generated in 0.03015 seconds
