Home » Newcomers » Newcomers » What's the advantage to use PlatformObject
What's the advantage to use PlatformObject [message #257639] Wed, 04 June 2008 04:12 Go to next message
Originally posted by: longhong1985.gmail.com
Hello! I am learning to write an subclass of the eclipse FormEditor. I
want to synchronize 3 formpage and one textpage and I find an example
about how to do this. In the example, the content of a formpage is saved
to an Platform Object and when this obj is changed the textpage is
notified about it. I am just confusing about why the obj should be
adaptable. What's the advantage of making the obj adaptable?
Re: What's the advantage to use PlatformObject [message #257660 is a reply to message #257639] Wed, 04 June 2008 09:56 Go to previous messageGo to next message
Read about the Adaptable framework here:
http://www.eclipsezone.com/articles/what-is-iadaptable/
Hope this helps,
Eric
Re: What's the advantage to use PlatformObject [message #257684 is a reply to message #257660] Wed, 04 June 2008 22:33 Go to previous messageGo to next message
Eric Rizzo 写道:
> Hope this helps,
> Eric
Thanks! IAdaptable looks like a tool making some
types converting possible.
Re: What's the advantage to use PlatformObject [message #257688 is a reply to message #257660] Wed, 04 June 2008 23:10 Go to previous messageGo to next message
Eric Rizzo 写道:
> Hope this helps,
> Eric
Thanks! IAdaptable looks like a tool making some types converting possible.
Re: What's the advantage to use PlatformObject [message #257692 is a reply to message #257660] Wed, 04 June 2008 23:38 Go to previous message
Eric Rizzo 写道:
> Hope this helps,
> Eric
Previous Topic:DSL integration with JUnit plguin
Next Topic:enable assertions for my plugin
Current Time: Tue Jul 22 00:44:55 EDT 2025
Powered by FUDForum. Page generated in 0.08448 seconds
