Home » Archived » Java WorkFlow Tooling (JWT) » [XPDL] Greetings
[XPDL] Greetings [message #25416] Mon, 02 April 2007 19:44
Originally posted by: steve.egbert.bull.com
Greetings:
My name is Steve Egbert and I work for Bull.
I work with Emmanuel and Miguel.
For the past year, and then some, I have been responsible for Bull's
graphical XPDL editor, which is called ProEd. It implements most of XPDL 1,
plus additional features that are available in the Bonita workflow engine,
so I have a passing fair familiarity with XPDL 1.0. We are in the final
stages of placing it into open source on ObjectWeb, under the Bonita
project.
I have added a considerable number of new featrues to ProEd, in the time I
have been responsible for it, and most recently have converted it to run
both as the original stand alone/webstart application and as an Eclipse
plugin. It uses the Swing based JGraph component for the node diagrams, and
so I have used the Swing-AWT bridge classes in implementing the plugin
version. The data model predates modeling frameworks, and is pretty much
based on the structure of the XPDL schema. I have attached some small
pictures of a couple of the graphical views of an XPDL that are available in
the ProEd plugin, in case someone is interested in seeing what it looks
like.
Steve
Previous Topic:[Metamodel] Initial metamodel uploaded
Next Topic:[scorware] 04042007 SCOrWare meeting notes
Current Time: Fri May 09 12:16:44 EDT 2025
Powered by FUDForum. Page generated in 0.02844 seconds
