Home » Archived » BIRT » Dynamically Altering Chart's Grouping - Round 2
| Dynamically Altering Chart's Grouping - Round 2 [message #257253] |
Fri, 05 October 2007 02:33  |
Originally posted by: clf.clf.com
Can anybody tell me why this doesn't work?
function beforeGeneration(chart, icsc)
chart.getPrimaryBaseAxes()[0].getSeriesDefinitions().get(0). getGrouping().setEnabled(false);}This is script embedded in the report. This does not error, but it alsodoes not turn my grouping off. It seems no matter what modifications I doto the grouping here, it does not take effect. It's almost as if thesettings from the GUI are applied *after* this code is executed (in otherwords, maybe my changes get overwritten by the settings done in the GUI).There doesn't seem to be any other events where I can do this.Any ideas?Thanks!
| Re: Dynamically Altering Chart's Grouping - Round 2 - PLEASE LOOK INTO THIS JASON [message #257258 is a reply to message #257253] |
Fri, 05 October 2007 03:09   |
Clf/Jason,
I am encountering the same problem. I am trying to modify my grouping
interval and unit on the base axis dynamically through the beforeGeneration
method and it doesn't get modified.
I logged the values of my interval and unit before and after modification in
the same method and it shows the correct values. I even tried logging the
modified values from beforeRendering and that is correct too.
importPackage(Packages.org.eclipse.birt.chart.model.attribut e);
//logged values of interval and unit from here - shows what I set through
the gui beforehand
chart.getPrimaryBaseAxes()[0].getSeriesDefinitions().get(0). getGrouping().setGroupingInterval(30);
chart.getPrimaryBaseAxes()[0].getSeriesDefinitions().get(0). getGrouping().setGroupingUnit(GroupingUnitType.DAYS_LITERAL) ;
//logged values of interval and unit-- shows the correct modified values
function beforeRendering(gcs, icsc)
{ //logged values of interval and unit from here -- shows correct modified
valuees
Looks like the setting in the GUI does override what I set.
Jason, is this a bug? If yes its a major hindrance to our progress. Could
you suggest a workaround?
PC
"clf" <clf@clf.com> wrote in message news:fe4lsc$a1v$1@build.eclipse.org...
> Hello,
| Re: Dynamically Altering Chart's Grouping - Round 2 [message #257266 is a reply to message #257258] |
Fri, 05 October 2007 03:22   |
Shortly after I posted the message, I did find a workaround, but I don't
know if it's an option for you. It does work if you use a Java event
handler (extending ReportEventAdapter) instead. So in otherwords,
overriding the same method, and doing the same thing we were trying in
Javascript... only in Java.
The only problem I'm finding with this is that I can no longer preview the
report, I get a ClassNotFound error.... report only works at runtime in my
app server, which is a big pain.
Anyway, that's a possible workaround for you... but I'd still like to have
the option to script this stuff if we can figure that out. I'm guessing
it's a bug. I'll probably add to bugzilla tomorrow.
"chakravp" <chakravp@us.ibm.com> wrote in message
news:fe4nou$knl$1@build.eclipse.org...
> Clf/Jason,
> beforeGeneration method and it doesn't get modified.
> in the same method and it shows the correct values. I even tried logging
> the modified values from beforeRendering and that is correct too.
> the gui beforehand
> valuees
> PC
| Re: Dynamically Altering Chart's Grouping - Round 2 - PLEASE LOOK INTO THIS JASON [message #257290 is a reply to message #257258] |
Fri, 05 October 2007 03:42   |
Some further investigation on this issue:
I disbaled grouping from the GUI and then enabled it from the
beforeGeneration method.
Surprisingly even though grouping is disabled, when I log the values for
isSetEnabled, grouping interval and unit before I make any modifications, it
shows up as enabled = true, interval= 1 ,unit = Hours--- that is the value
that was present before I disabled grouping through the GUI.
I created a fresh chart and tried the same thing. It shows enabled = true;
interval = 2; unit = Seconds. 2 seconds is the default grouping specified
by birt.
I logged the modified values in afterRender method also and they are
correctly modified.
-PC
> Clf/Jason,
> the gui beforehand
> valuees
> PC
>> Hello,
>> ideas?Thanks!
| Re: Dynamically Altering Chart's Grouping - Round 2 [message #257294 is a reply to message #257278] |
Fri, 05 October 2007 03:53   |
Thanks for your suggestion, Clf. But in my case I can't use Java event
handler :(
Definitely looks like a bug. Could you post the bug number once you have
opened it? I would like to track it.
PC
"clf" <clf@clf.com> wrote in message news:fe4ove$b9h$1@build.eclipse.org...
> Correction... I'm not overriding the same method in Java. I'm actually
> changing the grouping settings in beforeFactory of ReportEventAdapter.
> news:fe4oms$9rn$1@build.eclipse.org...
>> the report, I get a ClassNotFound error.... report only works at runtime
>> in my app server, which is a big pain.
>> have the option to script this stuff if we can figure that out. I'm
>> guessing it's a bug. I'll probably add to bugzilla tomorrow.
| Re: Dynamically Altering Chart's Grouping - Round 2 [message #257342 is a reply to message #257298] |
Fri, 05 October 2007 13:25   |
Hi David,
Thanks for the pointer.
I am able to call methods from the Chart interface like getPlot, getLegend
etc
But how do I get the axes of the chart?
This is the code I have in the beforeFactory
var chart = this.getReportElement("Chart1");
getPrimaryBaseAxes is not recognized as a method.
I tried typecasting the chart to ChartWithAxes and then trying that code.
That does not work either since I am not sure
how Rhino handles typecasting of java objects from within the javascript.
Any pointers on this would really help.
PC
"David Michonneau" <dmichonneau@actuate.com> wrote in message
news:fe4rg3$vkh$1@build.eclipse.org...
> Any script on the chart will be executed after the data has been bound to
> it. So changing the grouping model at that time will change the model
> effectively, but not the way the data is bound to it.
> You want to instead modify the grouping of the chart in the beforeFactory
> method of the report. See some explanations and examples here:
> http://wiki.eclipse.org/Calling_the_Simple_Chart_API_from_Sc ript(BIRT)
> David
>> Hello,
>> ideas?Thanks!
| Re: Dynamically Altering Chart's Grouping - Round 2 [message #257353 is a reply to message #257342] |
Fri, 05 October 2007 16:34   |
I was referring to the old API javadoc and hence was not getthing this
right. I was able to get this working from beforeFactory using the IChart
API docs
http://www.eclipse.org/birt/release20specs/BPS66/BPS%2066%20 -%20Chart%20Simple%20API%20SPEC.pdf
chart.getCategory().getGrouping().setGroupInterval(interval) ;
-PC
news:fe5rrl$f1g$1@build.eclipse.org...
> Hi David,
> etc
> PC
>> Thanks,
>> David
>>> Hello,
>>> ideas?Thanks!
| Re: Dynamically Altering Chart's Grouping - Round 2 [message #257404 is a reply to message #257353] |
Sat, 06 October 2007 03:41  |
Yes, this is the simple chart API which is more similar to remaining of the
DE script API than the internal chart model, which is quite complex.
Thanksm,
David
news:fe66v5$4mc$1@build.eclipse.org...
> API docs
> -PC
>> Hi David,
>> getLegend etc
>> Thanks,
>> PC
>>> Hi,
>>> to it. So changing the grouping model at that time will change the model
>>> beforeFactory method of the report. See some explanations and examples
>>> here:
>>> Thanks,
>>> David
>>>> Hello,
Current Time: Wed Nov 05 19:47:56 EST 2025
Powered by FUDForum. Page generated in 0.06244 seconds
