Debugging a Midlet [caution MTJ noob inside] [message #25382] |
Mon, 12 January 2009 10:54  |
my appologize in advance if I was to blind to find the right place ind
documenation... But I have no idea where else I could/should look.
I am more or less experince Java Developer for a couple of years and
developing various Applications (web & fat) over the last 10 years...
My problem is, that I can't get the Midlet-Debugger to work in my eclipse
Version: 3.3.2
Build id: M20080221-1800
I have installed Sun's wt2.5.2_01 - and running my Midlet is no problem at
all - everything works smooth like silk... but as soon as I wanted to
start my Midlet in debugging mode I see in the console:
Connecting to 127.0.0.1 on port 2800
Waiting for debugger on port 4105
Waiting for KVM...
Connection received.
Then the Phone-Emulater Window opens... and the console continue with this
lines:
Running with storage root c:\myDocs\noob24\j2mewtk\2.5.2\appdb\QwertyDevice
Running with locale: German_Germany.1252
Running in the manufacturer security domain
Connected to KVM
Then the only thing I can see, is that the lauhcn progress bar indicates
that he is arround 87% and then after some additional few moments the
Phone-Emulator-Window is closing again and the process is terminated.
Any ideas, what to check? - Again running my Midlet (or some I have
downloaded as examples) working fine... But I am not able to run any of
them in debug mode.
It would really kind, if somebody could guide me in the right direction.
TIA
Matthias Marquardt
Re: Debugging a Midlet [caution MTJ noob inside] [message #26199 is a reply to message #25382] |
Mon, 19 January 2009 04:16  |
Finally I found a workarround - do not ask my, why this is working - but
actually it does:
Adding a Entry breakpoint of the Method 'initializeInternalSecurity' in
the class 'com.sun.midp.main.Main'
so now each time I fire up my Midlet in DEBUG Mod the debugger stops at
this method but do not cause the crash of the zayit.exe
Re: Debugging a Midlet [caution MTJ noob inside] [message #570362 is a reply to message #25382] |
Mon, 12 January 2009 12:35  |
Originally posted by: news.s237965939.online.de
> at all - everything works smooth like silk... but as soon as I wanted to
I don't have a solution for your particular problem, but consider to
download and install the Motorola SDK too. I have both installed and
find the Moto better than Sun in many ways. Give it a try, perhaps it
provides you with more useful information about what's going on.
Hans
Re: Debugging a Midlet [caution MTJ noob inside] [message #570389 is a reply to message #25542] |
Mon, 12 January 2009 16:58  |
First of all thanks for your reply...
Gustavo de Paula wrote:
> try to add a breakpoint to the startApp method to see if it stops.
unfortunatly it does not stop - it happens exactly the same as before...
When I look at the command line (that is used to launch the app) then I do
not see anything "unnormal"...
RUN:
cmd /c emulator.exe
-classpath C:\temp\_mtj.tmpmarq24\PDPMidlet6370.launch\PDPMIDlet.jar
-Xdevice:QwertyDevice
-Xdescriptor:C:\temp\_mtj.tmpmarq24\PDPMidlet6370.launch\PDP Midlet.jad
-Xdomain:manufacturer
de.xxx.yyy.midlet.PDPMIDlet
DEBUG:
cmd /c emulator.exe
-Xdebug
-Xrunjdwp:transport=dt_socket,suspend=y,server=y,address=182 8
-classpath C:\temp\_mtj.tmpmarq24\PDPMidlet6369.launch\PDPMIDlet.jar
-Xdescriptor:C:\temp\_mtj.tmpmarq24\PDPMidlet6369.launch\PDP Midlet.jad
When I go to my 'jdk\wt2.5.2_01\bin' directory and launch there these
command lines (RUN/DEBUG) in both cases the Phone-Sim-Window shows up -
and they stayed up... Of course the DEBUG cmd line will cause to "hang"
since it looks like that the break point (I have set) is reached - but
since there is no connection to the IDE (obviously - since I have started
the app outside of eclipse) I could not step over this break point.
> besides that, when you run the debug for the first time
> it will request to do some changes on the debug settings?
> is this happening in your eclipse?
No - is does not - just allow me to repeat: You are saying, when I start
my Midlet in debug mode, the first thing that should happen is, that an
additional dialog should show up? - This does not happen for sure - even
when I start a complete new Midlet-Project. What kind of dialog should
that be? And what values I sould be able to adjust in there?
Matthias
> regards,
> gustavo
Re: Debugging a Midlet [caution MTJ noob inside] [message #570407 is a reply to message #25582] |
Mon, 12 January 2009 17:12  |
> ...Of course the DEBUG cmd line will cause to "hang"
this might be totally nonsense - sorry...
When I start the Midlet with the DEBUG cmd line options, then it's more
like, that my midlet does not start at all in the Phone-Sim-Window (the
window show up, but no matter what I do in the Midlet Constructor [like
System.out.println(...)] this output will not be shown
Re: Debugging a Midlet [caution MTJ noob inside] [message #570532 is a reply to message #25620] |
Mon, 12 January 2009 19:33  |
If you have not already, verify that your debug settings look similar to
these: http://eclipseme.org/docs/configuring.html#step4
(NOTE: I'm not sure where we are keeping the MTJ docs, but the EclipseME
docs should be pretty close in this case)
>> started the app outside of eclipse) I could not step over this break
>> point.
Re: Debugging a Midlet [caution MTJ noob inside] [message #570543 is a reply to message #25686] |
Tue, 13 January 2009 08:41  |
Thanks for your reply - yes indeed I have read & follow the prepare
Eclipse Section in the documentation.
I though the problem might had to do with the virus & firewall software
that is running here on my companys laptop, so I decided to install
everything frrom scratch on my private desktop.
The result is, that I can exactly launch any Midlet once per OS-Start. The
second time I launch the Midlet in Debug mode, the zayit.exe will crash
(In XP you get this: "zayit.exe caused a Problem - Do you want to send a
problem report")... (I can pos here the XML that is generated as well -
but I assume it will not help too much - since you are not developing the
WT) [I get this Dialog on my private Desktop only since the company
security policy is truncating this on my development Notebook]...
So when I reboot the system I can debug my Midlet once again for a single
time - the second time I get this "zayit.exe caused a Problem" thing
again. This is also reproducable on my Notebook [and I appologize for the
confusion I might have caused].
Actually it looks like the 'sun_java_wireless_toolkit-2.5.2_01-win.exe' is
the root ob the problem. Currently I am trying to get another version of
the sjwt (might be that the 2.5.2 or 2.5.1 will work for me)
Matthias
Re: Debugging a Midlet [caution MTJ noob inside] [message #570554 is a reply to message #25712] |
Tue, 13 January 2009 14:36  |
so it looks like that this is not a MTJ Problem at all - seams to me, that
this is a sun_java_wireless_toolkit problem - I have tried 2.5.1, 2.5.2 &
2.5.2_01 - with all of this versions I have the same problem:
Booting the PC, running the Debugger once - from there on I always
crashes...
Also got my hands on this sun_java_me_sdk-3_0-ea-win.exe - with that the
debugging seams to be working - but right now I am very confused about the
device definitions that comes with this ME SDK 3.0
So my final question: Is there another WTK, that's recomend to use (I plan
to develop phone vendor independant Midlet's...)
Re: Debugging a Midlet [caution MTJ noob inside] [message #570913 is a reply to message #25382] |
actually it does:
FUDForum. Page generated in 0.04133 seconds
